325es surging at idle/ driving when motor cold, getting horrible MPG - BMW Forum - BimmerWerkz.com
post #1 of 31 (permalink) Old 01-01-2007, 07:16 PM Thread Starter
whitey_E30's Avatar
whitey_E30 is an unknown quantity at this point
i was not having this problem before, it started about 2 months ago when the weather started getting cooler. it always surged at idle, but now its doing it while its driving before the engine warms up. also i getting horrible gas mileage. went from about 28-29 mpg down to like 20-21. just wonderd if they were related. i took it to a shop and they said replace the idle control valve. (a few others on the forum said so too in an earlier post) im just wondering if that will fix my mileage problem too.
this is my
whitey_E30 is offline
post #2 of 31 (permalink) Old 01-01-2007, 09:22 PM
Crazy Fabricatin' Admin
gotKRAUT's Avatar
gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute
i just cleaned my idle control valve for free just remove the idle valve and take a can of brake cleaner and hose it out, usually does the trick and saves you a chunk of cash
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast
gotKRAUT is offline
post #3 of 31 (permalink) Old 01-01-2007, 11:13 PM
Starmavin is a jewel in the rough Starmavin is a jewel in the rough Starmavin is a jewel in the rough Starmavin is a jewel in the rough
Like I said before the #1 cause of a screwed up idle and bad mpg is a faulty coolant temp sensor.
Starmavin is offline
post #4 of 31 (permalink) Old 01-02-2007, 12:38 PM Thread Starter
whitey_E30's Avatar
went and got a coolant temp sensor. i thought it mounted right up on the drivers side of the radiator but im not sure. it looks like there are 2 sensors thereand neither of them have connectors like the new sensor i got. maybe he gave me wrong part? the one i just picked up it the pic on the car hood. the one with the nice puke yellow plug. used:
ID:	25043   Click image for larger version
ID:	25044   Click image for larger version
this is my
post #5 of 31 (permalink) Old 01-02-2007, 01:22 PM Thread Starter
whitey_E30's Avatar
i think i found where the sensor could go but im not sure. theres only about 12 different places. help?
this is my
post #6 of 31 (permalink) Old 01-02-2007, 02:51 PM
gotKRAUT's Avatar
according to the bentley manual which every E30 owner should have its right there...
BTW love the avatar
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast
gotKRAUT is offline
post #7 of 31 (permalink) Old 01-02-2007, 05:47 PM
That is the coolant switch, that makes the car fast idle when cold. The yellow sensor is the correct one for the computer and idle module, it'll go right next to the #1 injector. You can get at it from the passenger side just under the air intake. There will be two sensors there, the one above it has one pin and that runs the gauge. The ones in the rad are the high and low speed fan switches.
P.S. The coolant switch is used in 87 and older cars with the idle control module, in 88 and up models the idle module is intergrated with the DME.
post #8 of 31 (permalink) Old 01-02-2007, 06:02 PM
gotKRAUT's Avatar
wow i was lookin at the pic in the bentley backwards, you are correct sir, its on the cylinder head, coolant outlet next to the thermo switch
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast
gotKRAUT is offline
post #9 of 31 (permalink) Old 01-04-2007, 09:38 AM
jfertita's Avatar
jfertita is on a distinguished road
so there is the coolant temp sensor and the thermo time switch, what are the differences and do they both contribute to bad mpg and erratic idle?
jfertita is offline
post #10 of 31 (permalink) Old 01-04-2007, 01:05 PM
gotKRAUT's Avatar
ones a sensor(just monitors temp) and one is a switch (sends a ground signal a certain temp) usually used for timing and idle control, but it is rarely the culprit because the only function it has is open or closed...closes below 86*F and open at about 118*F
idle valves get clogged which cause the surge, as i stated above, just take it off and hose it out with brake clean
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast
gotKRAUT is offline
post #11 of 31 (permalink) Old 01-04-2007, 06:35 PM
Ok, this should clear everything up. In all you have 6 temp sensors/switches on any 325 that is 87 and older. As mentioned before, the two in the radiator are for high and low auxiliary fan speeds.
The 4 in the motor found in and near the thermostat housing are as follows:
The thermo-time switch, this operates the cold start injector only, this is the larger one closest to the front of the motor.
Coolant temp switch is the next one back, is for cold warm up, this holds an open circuit until the cars coolant reaches the set temp then closes. gotKRAUT posted a pic pointing this one out.
Next one in has one pin and is for the gauge.
Then the last one is the coolant temp sensor, this is the most important sensor, it looks exactly like the sensor for the gauge but with two pins, this sends engine temp signal to both DME and idle control module.
post #12 of 31 (permalink) Old 01-05-2007, 08:54 AM Thread Starter
whitey_E30's Avatar
I got the coolant temp sensor in... but im still getting horrible gas milage and car still chugs before it warms up. so it didnt work. any more ideas.
this is my
post #13 of 31 (permalink) Old 01-05-2007, 05:43 PM
When cold remove the cold start injector then plug the hole with your thumb or anything that won't get sucked in, then have someone start the car, see if and how it is sprays fuel, hold a cup up to the injector it should spray a fine mist for 3-4 seconds then stop. While the car is warm, shut it off and remove the cold start injector, plug the hole, then have someone start the car, see if it is sprays fuel again.
post #14 of 31 (permalink) Old 01-17-2007, 07:18 AM Thread Starter
whitey_E30's Avatar
just replaced the ICV, and the car still is showing the same symptoms as before. erratic idle, poor fuel economy. i dont have much time to do work on it. is there anything else that is easily replacable that could possibly be the culprit??? it only does it when its cold. after driving for about 20 mins, it runs fine once it warms up while im crusing down the road.
this is my
post #15 of 31 (permalink) Old 01-17-2007, 08:07 AM
jfertita's Avatar
You can try testing your thermo time switch if you havent done that yet, only other thing i would suggest is vacuum leaks or something with your fuel system
jfertita is offline
325es surging in cold weather whitey_E30 3-Series (E21, E30) 3 10-28-2006 11:07 AM
