325es odd noise - BMW Forum - BimmerWerkz.com
Old 09-07-2004, 11:01 AM   #1 (permalink)
baram23 is an unknown quantity at this point
I've got a 325es that's making a whining noise at between 2k - 3k rpms, goes away when I take my foot off the gas or when i turn the steering wheel a bit. It doesn't seem to effect the car's driveability, but I'm wondering what it is and how much $$ it's gonna be to repair.
Thanks in adv. for your help.
baram23 is offline   Reply With Quote
Old 09-07-2004, 11:13 AM   #2 (permalink)
M-technik-3 is an unknown quantity at this point
Sounds like two issues. A wheel bearing and low diff fluid or gearbox fluid. Check the diff and gear box both can be done on a lift easy. top if needed then take car for spin noise gone great.
Start with simple stuff but don't just throw parts at it as you might never find it.
M-technik-3 is offline   Reply With Quote
Old 09-07-2004, 12:34 PM   #3 (permalink)
RealBMW 02's Avatar
RealBMW 02 is an unknown quantity at this point
Send a message via AIM to RealBMW 02
ya, checking fluids is always the first thing that you want to do when you hear a noise. It probably isn't a wheel bearing if the noise is dependent on engine rpm. Wheel bearings usually make a clunking noise when stopping. Could also be your power steering pump. I have heard those make some pretty weird noises that are variable with engine speed. Where does it sound like the noise is coming from? You said it goes away when you turn the wheel some, so its actually probably nothing to do with the tranny or rear end, but check those fluids anyway. well, good luck. keep us updated on what you find
<img src='http://files.unitedbimmer.com/ub.c/RealBmw%2002/Sig_ver2.jpg' border='0' alt='user posted image' />
1970 - 2002
Proud Memeber: 30+ year old car club
RealBMW 02 is offline   Reply With Quote
Old 09-07-2004, 06:04 PM   #4 (permalink)
Oxbrain is an unknown quantity at this point
Take a look at the boots over the wheel bearings. I had something like that happen on my car(geo) only happened during acceleration and went away with minor steering. One of the boots was slightly loose and rubbing on something.
Oxbrain is offline   Reply With Quote
Old 09-07-2004, 06:45 PM   #5 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
check the tranny and differencial fluid and check the drivline...shack it...it shouldnt move but your mounts could be going bad....
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 09-07-2004, 06:45 PM   #6 (permalink)
gotKRAUT's Avatar
Kyle Sutherland
1995 BMW 540i/6:
Old 09-08-2004, 01:10 AM   #7 (permalink)
thank you all for your advice
any recommendations for lube should i use in the diff?
Old 09-08-2004, 06:38 AM   #8 (permalink)
Says right in owners manual but it's SAE 90 or GL-5 1.7 liters total.
Old 09-08-2004, 03:01 PM   #9 (permalink)
Thanks for the info, unfortunately I don't have the owners manual. The dude I bought this from didn't know where it was, but for $500 USD I'm not gonna bitch too much.
Old 09-11-2004, 01:31 AM   #10 (permalink)
OK - found the source of the problem. Looks like wheel bearing is going bad in the rear passenger wheel. I was on the phone w/ phaedrus in san francisco while driving on the highway and the guy at the counter recommended that i slalom the wheel a little bit left and right and note whether the noise decreased depending on the direction. It gets worse when aiming right and less so when aiming left as he thought it would. Pulled off the highway and noticed there was some play in the wheel if it was pushed back and forth into the car.
Gonna take it in and have this fixed as well as get the diff fluid changed since it'll be up on a rack anyway.
Thanks a lot for your advice guys, gotta give you all props.
Old 09-11-2004, 06:03 AM   #11 (permalink)
Your welcome. You might want to consider an independant BMW workshop as labor will normally be less.
Old 09-11-2004, 03:25 PM   #12 (permalink)
Yeah, taking to phaedrus bmw in san francisco, they come pretty highly recommended by some friends. I'd like to try to do as much of the work as I an myself, but I don't have a garage available right now.
Old 09-12-2004, 12:48 PM   #13 (permalink)
BMW Lover's Avatar
BMW Lover is an unknown quantity at this point
Send a message via AIM to BMW Lover
yeah i have had experiance with that also, independent places are alot of the time cheaper for everything becasue they dont have as wide of a customer database as the actual bmw dealerships do.
^^I want this where I live.
&quot;Drag racing a BMW is like going fishing with a hooker, it's fun but it's not what you got her for...&quot; - M3DUDE
Manual - The transmission hated by moms/wives/girlfriends everywhere...
Member of the &quot;I Owned my Bimmer when I was 17&quot; Club
Member of the &quot;10 Year Old&quot; Club
Member of the &quot;3 Pedal&quot; Club
Member of the &quot;3 Light&quot; Club
BMW Lover is offline   Reply With Quote
What the HELL is making this NOISE???? bimmer_boy 3-Series (E36) 28 01-18-2008 07:15 PM
Ticking Noise From Engine Clint_M 3-Series (E36) 9 11-07-2004 11:02 AM
front end noise fushuman 3-Series (E36) 4 09-20-2004 04:21 PM
loud noise - including clicking tsinghbmw 3-Series (E36) 6 06-01-2004 02:25 PM
