325e help.... - BMW Forum - BimmerWerkz.com
Old 05-18-2004, 07:58 PM   #1 (permalink)
pointedem is an unknown quantity at this point
So im new here, just got a 325e and need some advice
My right front brake system is having a hard time, to say the least.
i was driving today and noticed the car was slowing down w/o braking.
got home, and the wheel in question was piping hot.
the rotor is blackend- i took the tire off and it looks like the pad is pressing down on the rotor- no brake pedal pressure, obviouly..
What do you guys think is the problem and the solution.
also, when i go WOT sometimes, the car has signifgant lag.. kinda like a small series of lurches- almost like fuel isnt getting to the engine- then after 4-6 seconds at the longest it will "catch" and rev normally... Im running 93 octane- the chick i bought the car from did not wind er out often( non- agressive driver_ Do you think it may be the fuel system cleaning it self out (hopefully)
thanks,
pointedem
pointedem is offline   Reply With Quote
Old 05-18-2004, 09:34 PM   #2 (permalink)
viali8 is an unknown quantity at this point
i am not sure but it could be the calipers sticking. i do not know how to fix that problem. hopefully some of the more experienced owners will give u some pointers.
viali8 is offline   Reply With Quote
Old 05-19-2004, 12:57 AM   #3 (permalink)
heifetz17's Avatar
heifetz17 is an unknown quantity at this point
Send a message via MSN to heifetz17
Perhaps your injectors are clogged. Have you run a fuel system cleaner through the engine? You might do that on your next fill up. Also, you may be running slightly rich, which could give you that pulsating feeling. Check to see if your exhaust is black. Also, check to make sure no gas is in the oil, which can come from running rich. I don't know about the brake. Maybe your rotor is warped.
heifetz17 is offline   Reply With Quote
Old 05-24-2004, 11:21 PM   #4 (permalink)
300k 325e is an unknown quantity at this point
i have an 85 325e and its having the SAME problems, being an ASE certified tech, i have access to some tools you dont have, such as a pair of very knowledgeable master techs familiar with early EFI and imports. we used the mitchell online program they have and found the resistance/voltage values for the AFM and found that it was working fine, but the motronic control unit (ECU) may be the culprit, there was a fairly large crack in the intake pipe but i fixed that with no results, the only things on the car that have the ability to control fuel and richen it THAT much are the AFM and coolant temp sensor, and those are only 20 bucks on ebay or at parts stores, the O2 sensor just "trims" the fuel. mine runs rich too, it seems like cylinders will shut down and after several seconds of WOT the dead ones come back online. i have also noticed that avoiding sudden throttle changes while driving can keep this from happening, if i drive down the road and close the throttle suddenly and open it back up causing it to "hiccup" then the problems will manifest themselves. plugs and wires, cap and rotor couldnt hurt, i would like to have some answers though.
300k 325e is offline   Reply With Quote
Rim Bolt Pattern 325e? Enthuziast 3-Series (E21, E30) 6 10-23-2005 08:35 PM
325e Crank, 325i Block Abdul 3-Series (E21, E30) 2 02-22-2005 08:36 AM
e30 325e VS e36 325is catalyst. 3-Series (E21, E30) 10 08-05-2004 11:40 AM
325e Mods pogiboy9 3-Series (E21, E30) 16 05-06-2004 09:47 PM
325e and 325i/is bigred318 3-Series (E21, E30) 17 03-26-2004 04:12 PM
