318is Hesitation when hot - BMW Forum - BimmerWerkz.com
post #1 of 18 (permalink) Old 07-10-2006, 12:26 AM Thread Starter
MLC834's Avatar
MLC834 is on a distinguished road
Anyone ever experience this problem, I have a 91 318is, engine runs fine when first started, however once warmed up or hot, when I try to start it it, sputters as if its lacking fuel. I already have changed the fuel pump, fuel pressure reg, cleaned spark plugs, wires, ports etc. Disconnect O2 sensor to see if it is operating properly, car runs like crap without it so I know it works. Kinda feed up, any suggestions.
Thanks
JJP
MLC834 is offline
post #2 of 18 (permalink) Old 07-10-2006, 06:01 PM
Starmavin is a jewel in the rough Starmavin is a jewel in the rough Starmavin is a jewel in the rough Starmavin is a jewel in the rough
Do an ohm test on your AFM. Check the quality of the spark. Also check your ECT (engine coolant temp sensor) the one for the computer, not the guage. Is your check engine light on?
Starmavin is offline
post #3 of 18 (permalink) Old 07-10-2006, 11:02 PM Thread Starter
MLC834's Avatar
Starmavin,
Thanks for the reply, just want to make sure that the ECT is the sensor located below the fuel rail just back of the oil filter. and that the sensor that operates the gauge is located on the radiator, yes. Also what is meant by AFM? The ckeck engine light is fine and does not illuminate. I'll give it a try. Thanks again
JJP
MLC834 is offline
post #4 of 18 (permalink) Old 07-10-2006, 11:13 PM
Sodium Chloride
saltshaker185's Avatar
saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold saltshaker185 is a splendid one to behold
you say fuel pressure regular? i would go ahead and put in a fuel injector cleaner while you at it just to get it running better... do you have an after market air intake? maybe after it warms up it just isnt getting the quality oxygen it needs and isnt igniting as well as it should, hince what starmarvin was comming around to and i double, check to see the quality of the spark... that may be your problem...
saltshaker185 is offline
post #5 of 18 (permalink) Old 07-10-2006, 11:59 PM Thread Starter
MLC834's Avatar
saltshaker185
I installed a K&N aftermarket cone style air filter and gutted the OEM box style filter. I was experience the problen well before that particular mod. Will add fuel injector cleaner though. Would a faulty coil cause this particular problem and if so how do you determine which of the four coils it is?
Thanks guys, learning big time by read other post as well, managed to fix a few problems by process of elimination with little or no cost.
JJP
MLC834 is offline
post #6 of 18 (permalink) Old 07-11-2006, 03:30 PM
and0pand0 is on a distinguished road
Heh
Well, this is funny because I have the same exact car and it does the same exact thing. It's been doing it forever now. Sometimes it'll even die at stop lights.
Check for an open between the AFM ground and IAT sensor (it's bundled with the AFM). Mine's open and needs a new AFM. While I don't belive this would cause the problem, if you have the same issue, then maybe it is. Normally it would just make the engine run richer all the time, and I have seen this on my O2 sensor.
I've checked my idle control valve, fuel pressure, changed plugs/wires/coils, removed intake manifold and changed gaskets along with all the vacuum hoses etc., checked the TPS sensor, checked my purge valve to make sure it only purges at cruise... Everything checked out fine, 'cept for the AFM's IAT sensor. The only thing I haven't checked is the coolant temperature sensor, mainly because I remember it being in a hard to reach spot. I'm thinking of just buying one and seeing if it helps. However, I know the IAT sensor is shot. Anywho, keep this thread alive please!
-And0
and0pand0 is offline
post #7 of 18 (permalink) Old 07-11-2006, 03:48 PM
Also, I've checked the TPS sensor already. Just wanted to put that out there..
-And0
post #8 of 18 (permalink) Old 07-11-2006, 08:47 PM
There is another thing to check, however to do it correctly you'll need an oscilloscope. I have come across a few barely running motors with no obvious reasion why. And I have found that a bad or cruddy CPS can send a weak, but readable wave form causing the car to run like crap. This is a uncommon condition that should be tested first before throwing money at it. I don't want anyone giving me any greif that they shot out to the parts store and sank $100 for nothing. I do stress that you should search out all other options FIRST, such as build up on the sensor head (gunk, or rust), poor grounds, dirty sensor plug contacts, clogged injectors, weak relays, etc.
post #9 of 18 (permalink) Old 07-11-2006, 11:00 PM
ahhh
Hmmm hadn't thought of that. I don't have a lab scope though =( Any other ideas on how to test it? Wouldn't that cause more of a hard-start condition? It does seem like the engine is missing when it has this "hesitation". I'd say it's more of a stumble. I've hot soaked this car before a couple times and it doesn't fix the problem. I changed the plugs right after too. No help =(
post #10 of 18 (permalink) Old 07-13-2006, 12:37 AM Thread Starter
MLC834's Avatar
hey guys,
no progress with vehicle thus far, changed the ECT sensor and secured (Clamped) off a couple of hoses to rule out any obvious vaccum leaks, working on researching some of the acronyms that have been thrown my way, I'm probably one that needs it spelled out, getting there though. Once resolved I'll let you know.
Thanks andopando/saltshaker/starmavin
JJP
MLC834 is offline
post #11 of 18 (permalink) Old 07-14-2006, 01:14 AM
ahhh
So it's not the ECT then? Damb! Did you check your IAT sensor? (intake air temperature sensor, it's bundled inside the AFM (airflow meter))
post #12 of 18 (permalink) Old 07-15-2006, 09:30 PM
bump
post #13 of 18 (permalink) Old 07-18-2006, 10:03 PM Thread Starter
MLC834's Avatar
Hey andOpandO
what is meant by "bump"? Anyway I tested the AIT sensor and it remains open as you suggested, unfortunately there is no way to replace it as it is in fact bundled with the AFM so the whole unit needs replacing. I also read that as a result of the AIT sensor failure it sends a reading to the ECU and place the car in a "limp home" status, this is probably why I'm still able to drive the car normally once the hestitation ends. Pelican Part want's 180 bucks for a replacement AFM, do you know of any place less expensive, the car is very much drivable just a pain in the ass when starting off on the second leg . Any suggestion on what may fail next so I can be prepared (Common problems you've experienced
Thanks
Jay
JJP
MLC834 is offline
post #14 of 18 (permalink) Old 07-18-2006, 10:07 PM
Hah!
Damn, I was right!
Anywho, I have no clue where to buy one cheaper than that. That sucks they're so expensive =( At least we got to the bottom of this. THANK YOU for replying!
BTW, a "bump" is when you just put a post on a thread to bump it up higher in the thread list.
Good work!
post #15 of 18 (permalink) Old 07-18-2006, 10:13 PM
Wait!
You could CAREFULLY try opening the AFM and seeing where the IAT was severed from it's ground. That's about the only thing I can think of. Just make sure you re-seal it very carefully with some silicone or something. I was thinking of just adding a couple resistors to the signal wire and "fool" the computer into thinking the air outside is cooler and making it add fuel to the mixture, but it's prolly a better idea to just buy a new AFM =(
91 318is Sputtering Problem MLC834 3-Series (E21, E30) 3 07-06-2006 12:13 AM
91' 318is sexydylan05 3-Series (E21, E30) 8 05-15-2006 09:49 PM
Price For My 318is tagerman 3-Series (E36) 7 06-22-2005 04:30 PM
318i vs 318is vs 320i Sabih 3-Series (E36) 18 08-07-2004 12:28 AM
E30 318iS vs E36 318iS LondonE30-318iS 3-Series (E21, E30) 16 03-22-2004 01:32 PM
