318i Radiator Problems - BMW Forum - BimmerWerkz.com
Old 07-25-2004, 09:04 PM   #1 (permalink)
W00T
Numark318i's Avatar
My bimmers been having radiator problems, and I dont know what to do.
MY fluid runs low after about 250-300 miles in the radiator thus making the car over heat. I have changed the cap, that did nothing. I also checked for leaking fluid, no luck. I have gotten 2 oil changes since I realized the problem, and no water in the oil.
Help me! I almost overheated the other day while caltrans was being slow....so I need some anwers cause its gonna fuck(sorry) something up on the car ghead
Ps..only happens if I am at a stand still, or idle.
Old 07-25-2004, 09:12 PM   #2 (permalink)
Old_School_Bimmer's Avatar
Old_School_Bimmer is an unknown quantity at this point
Send a message via MSN to Old_School_Bimmer
when the car is running hot the coolant might evaporate and it might only leak from a hose when it heats up because the hose expands after u drive it for a while pop the hood and check for leaks before it cools down
Old_School_Bimmer is offline   Reply With Quote
Old 07-25-2004, 09:53 PM   #3 (permalink)
angryrobots is an unknown quantity at this point
Or your water pump could have gone tits up, causing the coolant to boil out.
angryrobots is offline   Reply With Quote
Old 07-25-2004, 10:17 PM   #4 (permalink)
W00T
Numark318i's Avatar
well i just talked to my dad...he tells me it might be the thermostat for the water pump....Ill try that first cause its cheaper. So i guess if that goes out the pump wont kick in.
Thanks for help, ill update with the news..hopefully i can fix it.gonna order the part tomarow
For Sale: 1984 318i And '85 Non-run Parts 318i mdaitc 3-Series (E21, E30) 4 07-26-2009 12:52 PM
An ALPINA 318i!? I'm I seeing correct? Delmarco 3-Series (E36) 1 09-10-2005 05:09 PM
Does An '85 318i Have Power Steering? dsio 3-Series (E21, E30) 1 03-31-2005 09:32 AM
Under The 318i Hood! 1995 Vs. 1996! Delmarco 3-Series (E36) 13 11-05-2004 08:24 AM
