318i head gasket - BMW Forum - BimmerWerkz.com
Old 06-07-2011, 10:13 PM   #1 (permalink)
epighany's Avatar
Car: 1994 318i
epighany is on a distinguished road
Exclamation 318i head gasket
Hello my friend is giving me his 318i but it needs the head gasket replaced. The car runs like a dream but it overheats. My question is since it is running fine (but that problem) is it best to get it replaced or use a sealant in the meantime? I also know to replace it will cost around $1200.
Thank you
epighany is offline   Reply With Quote
Old 06-08-2011, 02:04 PM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
This happened to my E38 a couple of months back...
1- Does it spout out of the Rad?
2- Is the oil on the dipstick milky?
If no to both questions then put a small bottle of K-Seal in the coolant and top up as necessary!
Cured my overheat INSTANTLY !
If Yes, then maybe TRY a bottle of K-Seal first, but do not expect God to take over LOL
Should work though and its gotta be worth a try?
BTW I am not employed by the company, I bought a bottle !
DAZ
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 06-08-2011, 02:34 PM   #3 (permalink)
epighany's Avatar
Car: 1994 318i
Question
ok I am new I added to the wrong spot! is it really that simple to just add it to the radiator? Does it need to be empty? Yes I am a dumb woman when it comes to this. I exaggerated my friend is selling it to me to me for $1000. So as far as I know nothing is coming out, if it does work should I eventually get it fixed? If so where should I go to a BMW dealer or is there a type of Mechanic I should goto??
Thanks a million~~~
Old 06-08-2011, 02:43 PM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Just add it... And mybe top up to the correct level if you need to.
Let it do its work for a run and then you will have your answer whether or not to get the gasket done..
DAZ
It worked for me, princess !
Eso es todo!
BMW Part Market
New Member ?
Old 06-08-2011, 02:57 PM   #5 (permalink)
epighany's Avatar
Car: 1994 318i
Ok thank you so much I owe you lunch!!
Old 06-08-2011, 03:00 PM   #6 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
If you are happy then PLEASE use the "REP" button on the left side for me, I am always here to help !!
DAZ
Eso es todo!
BMW Part Market
New Member ?
Old 06-09-2011, 06:56 PM   #7 (permalink)
epighany's Avatar
Car: 1994 318i
Onr more question...when I put it in and if the car happens to start to run hot do I let it continue and work its magic? Or do I stop??
Old 06-10-2011, 01:11 PM   #8 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
It really should be doing its job in the first 5-10 mins anyway !
Google K-Seal
Eso es todo!
BMW Part Market
New Member ?
Old 06-18-2011, 06:00 PM   #9 (permalink)
epighany's Avatar
Car: 1994 318i
Question
Ok I got the car today and I didn't get K-seal I got Steel Seal instead. I don't know where the radiator is so pray for me!!!!
Old 06-19-2011, 09:58 AM   #10 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Praying to the almighty allah !! LOL
Eso es todo!
BMW Part Market
New Member ?
Old 06-19-2011, 12:00 PM   #11 (permalink)
epighany's Avatar
Car: 1994 318i
Cool
I found the radiator (my mom showed me...lol) I will let you know how I made out!!
Old 06-25-2011, 10:33 PM   #12 (permalink)
epighany's Avatar
Car: 1994 318i
Ok I did the steel seal.through the hose (with help) we did it for 1 hour flushed the hose and the radiator with water, then filled it with antifreeze. After 30 minutes it did run hot but not totally in the red where the warning buzzer comes on. So I am hoping after sitting over night it wont run hot. If it does what should I do?
Old 06-26-2011, 06:33 AM   #13 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Did you put the steel seal in LAST?
Eso es todo!
BMW Part Market
New Member ?
Old 06-26-2011, 07:01 AM   #14 (permalink)
epighany's Avatar
Car: 1994 318i
Question Head gasket
We put steel seal into the hose ran it for the hour then flushed water into the radiator compartment with the plug pulled then did the same in the hoses that connects the raidiator , but we disconnected it from the radiator. After we flushed it and made sure the water was cold that we flushed out we replaced it with antifreeze put it in the hose diredtly to the motot and filled it in the. Radiator. It was amazing to see all the smoke and waer then nothing. The car did run hot a little that was last night I haven't drove it yet. So to answer your question no antifreeze was the very last we put in the car and let it cool
Old 06-26-2011, 08:09 AM   #15 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Oooops You may have flushed it out a little... It should have been applied after the flushing and at the same time as antifreeze, maybe...
Eso es todo!
BMW Part Market
New Member ?
Blown head gasket, Cracked cylinder head... Blackoutmp M-Series (M1, M3, M5, M6) 8 04-04-2006 01:51 AM
Blown Head, Or Head Gasket? mike11787 3-Series (E36) 4 08-27-2005 07:34 PM
Help Does A Blown Head Gasket/head Make Noise? E36k224 3-Series (E36) 7 03-17-2005 12:18 PM
Blown head gasket, new motor or new gasket? Bmw528i 5-Series (E12,E28, E34, E39, E60) 9 07-07-2004 01:06 AM
head gasket vs cylinder head crack bderrick 3-Series (E21, E30) 3 07-04-2004 01:55 PM
