215/40-r17 - BMW Forum - BimmerWerkz.com
post #1 of 15 (permalink) Old 04-15-2004, 09:35 AM Thread Starter
Le_max is an unknown quantity at this point
hey guys, this is a first time post!
I have read posts from you guys for a while... great forum!
I heard that 215/40/r17 with 20mm offset is the largest tire size
you can go with when you have a approx 1.5 inch dropped suspension.
I wanted to know where does it rub when you go with 225/40/r17?
Front, Rearn, on the fenders? inside the wheels holes?
Is there a work around to install 225 or 235 on a dropped suspension
e30
I got a 1989 325i, chipped, tokico blue shocks, H&R sport springs, Lock Diff from
a 325is, custom front valence, angel eyes, Recaro Seats. And a 1988 325is for spare parts.
Le_max is offline
post #2 of 15 (permalink) Old 04-15-2004, 12:36 PM
'85 318i's Avatar
'85 318i is an unknown quantity at this point
Send a message via AIM to '85 318i
sorry I can't help with your question. But... got any pics of your car?
No posers, hacks or sellouts allowed.
"Only posers die..." - Stevo "SLC Punk!"
'85 318i is offline
post #3 of 15 (permalink) Old 04-15-2004, 12:55 PM Thread Starter
you would not want to see it, the body is in really bad shape....
and I'm still with the stock bear bottle cap wheels!
will have photos in 3 weeks.... hopefully with some nice wheels
and some body works done.
Also, I have a set of BBS 14 inch from a 1988 325is. One of them
is destroyed due to an accident. Assuming it was a set of 4 in good
condition, are these worth some money? Maybe I could buy a single
wheel and sell the complete set?
thanks.
Le_max is offline
post #4 of 15 (permalink) Old 04-15-2004, 03:43 PM
Welcome le max,
offset is for wheels, but you shouldnt go higher than et25 if you want to fit 225's, in order to clear the strut. with a 89, you will need to roll the rear fenders with 225's and possibly the fronts, but i havent heard of a 225/40/17 tire so you may be out of luck
MrM3 is offline
post #5 of 15 (permalink) Old 04-15-2004, 04:42 PM Thread Starter
you are right for 225/40/17 no availabitlity, I was searching for this tire size just today.
About the offset, I'm shopping for wheels right now, tell me one thing, what is "et25" does it mean offset of 25mm?
I think I will go with 215 mm tire, Would 7.5 inch or 8 inch wheel would fit? with this width, do I keep an offset of 20mm? Because I like the look of "streached" tire on a mag wheel.
thanks for your help guys, this info is really hard to find.
Le_max is offline
post #6 of 15 (permalink) Old 04-15-2004, 04:44 PM
DeathMetal's Avatar
DeathMetal is an unknown quantity at this point
what does "roll the fenders" mean?
<span style='color:blue'><span style='font-size:14pt;line-height:100%'>Member of the Out of the Closet &quot;I Listen to Metal and own a Bimmer&quot; Club</span></span>
DeathMetal is offline
post #7 of 15 (permalink) Old 04-15-2004, 07:04 PM
BimmerKris's Avatar
BimmerKris is an unknown quantity at this point
WWWWAAAAAIIIIITTTTT!!!!!!!!
I got 225/45r17s on the back of my car with a 2in drop and nothing done. The tire only rubs in hard corners or big bumps. I have the offsets ordered but right now it is striat off the hub.
Here are some pics
<img src='http://bmwforums.penguinstudios.com/BimmerKris/salesig%20copy.jpg' border='0' alt='user posted image' />
<a href='
target='_blank'>
100% thrash your face off metal
BimmerKris is offline
post #8 of 15 (permalink) Old 04-15-2004, 07:04 PM
BimmerKris's Avatar
and one of just the tire
<a href='
target='_blank'>
post #9 of 15 (permalink) Old 04-15-2004, 07:23 PM Thread Starter
yeah, you got a 1988 and older, I heard those are easier to fit 225 with a 2inch drop.
fender rooling is hard to explain (even more when english is you second language, I'm from Quebec!)
It is when you bend the inside horizontal part of the fender (the fender part over the wheel) you bend it so it become vertical. This way, the fender takes less place in the wheel hole. Hope it is clear enough.
P.S. YEAH!!!!! the Montreal Canadians just scored the Boston Bruins!!!!! just a second ago!
Le_max is offline
post #10 of 15 (permalink) Old 04-15-2004, 07:25 PM
Here are some pics
yeah but they still rub. 225/45/17 tires are deffinately oversize for a e30. ive seen them up close next to my car when i was parked next to a 330ci and thought it looked out of proportion. putting spacers on probably wont help anything since they will put the wheel closer to the fender lip and may cause more rubbing
MrM3 is offline
post #11 of 15 (permalink) Old 04-15-2004, 07:26 PM Thread Starter
Here are some pics
what does "I have offset ordered" I guess you mean "spacers"?
Le_max is offline
post #12 of 15 (permalink) Old 04-15-2004, 08:23 PM
BimmerKris's Avatar
yeah my great typing skills at work there.
I'm getting the offest mostly for looks from the back. There is probably 2 in beween the fender and the tire yet. From the looks of things, it should stop the rubbing all together. At first i thought they were a bit over kill too. but they defenitaly grew on me. I needed something bigger to get more bite. I burned off the 215/40's way to fast. These are nice, give me really good launches and stick in beween shifts. I imagine there is a tiny loss in wheel power, but for some reason, it feels torqueyer (a yeah) . Is this because the tire bite better? mind you i even feel it just stepping on the gas while cruising.
<a href='
target='_blank'>
post #13 of 15 (permalink) Old 04-20-2004, 10:26 AM Thread Starter
anybody on that issue? et25???? what is it
Le_max is offline
post #14 of 15 (permalink) Old 04-20-2004, 04:26 PM
Originally posted by Le_max+Apr 20 2004, 10:06 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Le_max @ Apr 20 2004, 10:06 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Le_max@Apr 15 2004, 04:22 PM
anybody on that issue? et25???? what is it [/b][/quote]
yes et25 means 25mm offset, et40 = 40mm offset, etc
MrM3 is offline
post #15 of 15 (permalink) Old 04-20-2004, 04:30 PM Thread Starter
ok, but, how about et35?
just kidding, :lol: Thanks man!
Le_max is offline
