1989 325i check engine light - BMW Forum - BimmerWerkz.com
Old 01-21-2004, 05:38 PM   #1 (permalink)
CLW
CLW is an unknown quantity at this point
The check engine light to the left of the SI board came on during a fuel pump relay problem. With fuel situation now corrected the lamp is still illuminated. Bentley says starting car 5 times will shut it off but so far has not happened. Oil and inspection reset tool has not turned it off either. Any advice appreciated on how to reset light. Thanks!
CLW is offline   Reply With Quote
Old 01-21-2004, 07:18 PM   #2 (permalink)
You still have an issue that needs corrected.
Here is a link to the test.
http://www.bimmerzone.com/fcodes.htm
Later,
<img src="http://kcrealtime.com/dyno-max_900_hp.gif">
KC Ron Carter is offline   Reply With Quote
Old 01-22-2004, 04:37 PM   #3 (permalink)
CLW
Thanks for the help!
'94 318is Uneven Idle. Check Engine Light On ultraviolet353 3-Series (E36) 8 12-19-2004 11:17 PM
Check engine light Necktie 3-Series (E46, E90) 3 06-26-2004 01:54 PM
'88 M6 Check engine light jfries 1,6,7,8 - Series and Mini Cooper 0 05-27-2004 09:37 PM
Check Engine Light came on today camnipotent 3-Series (E36) 22 05-17-2004 06:23 PM
check engine light and check light Scarface 3-Series (E36) 3 06-03-2003 08:31 AM
