1987 BMW 325is Won't Start. Help Please!!!! - BMW Forum - BimmerWerkz.com
Old 11-26-2003, 08:26 AM   #1 (permalink)
kai0110 is an unknown quantity at this point
Send a message via AIM to kai0110
Arrow
I have a 1987 325is that just won't start. I took the fuel line going onto a long black bar close to the intake. Should fuel be coming out when I am cranking it? It has been sitting up for 3 months. I have another 1988 325i used primarily for parts. I noticed I am not getting any fire from the ignition coil using a somple ground test and voltmeter test. Another thing I have done to check for fuel is to take the fuel line off of the fuel filter and put my finger over the line to see if it is sucking or does the fuel pump "push" the fuel to the engine. I took the ignition coil from the parts car and placed it on the good one.
I am in serious need of some advice!! Can someone please help me. ghead
Thank you in advance
kai0110 is offline   Reply With Quote
Old 11-26-2003, 09:46 AM   #2 (permalink)
Out side the fuse box are three relays.
they can be moved to different locations.
The only way to know is to check the wire colors.
The five prong is the main relay
RD
RD/WT
GN
BR
BL/RD
Fuel pump relay
RD
RD/WT
GN/VI
BR/GN
o2 sensor heater relay
GN/VI
GN/YL
GY/BR
GN/BU
On the fuel pump relay, short from pin #30 to #87.
This should cause the pump to run if fuse #11 is good.
Later,
<img src="http://kcrealtime.com/dyno-max_900_hp.gif">
KC Ron Carter is offline   Reply With Quote
Help E39 Won't Start SKT174 5-Series (E12,E28, E34, E39, E60) 12 07-25-2009 10:03 AM
1987 BMW 325is 79k miles $5800 e30collector Cars For Sale 0 09-16-2005 01:42 PM
Car Won't Start - Help - Fuel Pump Relay? e36is 3-Series (E36) 24 09-08-2005 05:51 PM
'93 325i Won't Start 86VFR750R 3-Series (E36) 3 12-05-2004 08:32 AM
325I won't start in heavy SUNLIGHT 325iconverted 3-Series (E21, E30) 3 07-09-2004 12:15 AM
