1983 325E clutch problem - BMW Forum - BimmerWerkz.com
Old 07-01-2003, 02:18 PM   #1 (permalink)
will1506 is an unknown quantity at this point
Send a message via ICQ to will1506 Send a message via AIM to will1506 Send a message via MSN to will1506 Send a message via Yahoo to will1506
hey guys my clutch just died on me. I stopped at red light with my feet on both the clutch and the brakes. when the light turned green I ahve noticed that my clutch woudlnt' come up. I managed to leave the car in second gear and drove it back home a coup;le of blocks riding on the clutch. And when I was home I was playing with the clutch. I can press the clutch down half way and it will sink to the bottom all by itself. it looks like that there's some kinda hydrolic effect happening. I don't know what could be broke. I am suspecting hte spring or the cylinders. It will jsut sink to the floor and to get it back up I'll have to pull it up manually with my hand. I don't have to push it all the way to the floor. if I push it half way it looks like that the hydolics is pulling it down. I don't see any leaks anywhere and the fluids are topped up.. What do you guys think?
will1506 is offline   Reply With Quote
Old 08-05-2003, 02:09 PM   #2 (permalink)
BMdubnU_325es's Avatar
BMdubnU_325es is an unknown quantity at this point
Send a message via AIM to BMdubnU_325es
might be a fluid problem
check your clutch fluid
you might need a whole new clutch i did...i got a SACHS clutch for $600 its a good clutch
<span style='font-family:Arial'><span style='color:blue'>1987 BMW 325es</span></span>
BMdubnU_325es is offline   Reply With Quote
Old 08-05-2003, 02:12 PM   #3 (permalink)
lwebb12's Avatar
Car: 2000 M5
lwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond repute
Send a message via AIM to lwebb12 Send a message via Yahoo to lwebb12
well either your slave cylinder or master cylinder is bad. in a hydraulic system you always have a master and a slave. you can cap the master and push in the clutch pedal. if you get a lot of resistance to the point where you cant move it then the master is good but slave is bad. if the pedal still falls to the floor then it will be the master.
Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
lwebb12 is offline   Reply With Quote
Is This A Clutch Problem? frank3 3-Series (E36) 18 05-15-2012 12:01 AM
Clutch Problem Possibly? Saukk 3-Series (E46, E90) 7 08-27-2005 05:30 PM
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
a possible clutch problem? Furious 3-Series (E36) 6 12-20-2003 02:37 AM
