Hello All.
I have a 96 BMW z3. Love the car. The check engine light came on and i took it in to get checked out. My mecahnic said the O2 sensors needed to be replaced. I just replaced them about 8 mos ago. So, I had them replaced for the 2nd time. On my drive home from the shop the check engine light came back on. Took it back to the mechanic and he said the O2 sensors were bad and they need to be replaced again. My concern is that this isn't the real problem. Hoping someone can give some insight.
Thanks -- Kelly
i smell something... since this car is OBDII, you can take it to asdvance auto parts, and they will be able to give you the diagnostic codes, and maybe an explaniation behind them
make sure that the mechanic deleted the old faults in the computer. he could just be reading the old one from before. i think the car has to go through a couple drive cylces with out a problem before the engine light will go out on it's own.
Yea, that sounds like BS to me. You might want to try to verify the fault code yourself. Go to Peakes Research and get your self a code/reset tool. I have one and I know what the code is before I get to the mechanic. In fact you might want to tell the idiot Mechanic to get one himself. Sometimes something stupid as a loose gas cap can give you a false code. The dealer charges you $ to reset the code, you might as well do it yourself. By the way they also have the reset tool on ebay for a few dollars less.
Originally posted by ZeeMe@Apr 17 2005, 06:35 AM Yea, that sounds like BS to me. You might want to try to verify the fault code yourself. Go to Peakes Research and get your self a code/reset tool. I have one and I know what the code is before I get to the mechanic. In fact you might want to tell the idiot Mechanic to get one himself. Sometimes something stupid as a loose gas cap can give you a false code. The dealer charges you $ to reset the code, you might as well do it yourself. By the way they also have the reset tool on ebay for a few dollars less.
[snapback]333806[/snapback]
Definately make sure to have them reset the fault codes before they really replace stuff. On mine and my friends vehicles I always reset them with the tech II before I fix ANYTHING. One fault code has a tendency of setting off other fault codes if you keep driving while the check engine light is on. The only way of knowing what is really wrong is resetting it and waiting for it to come back on, and checking what are the stored codes after that.
