X5 sunroof removal - BMW Forum - BimmerWerkz.com
Old 08-21-2004, 08:14 PM   #1 (permalink)
nag
nag is an unknown quantity at this point
To make a long story short, I messed up and need to replace the headliner in my 04' X5. (note: always ask wife to wrap sharp corners of picture frame before trying to put in X5)
I am in the process of removing the old head liner but I'm stuck. If you put the sun roof back, there are small screws from the top that screw into the headliner. Its no problem removing the screws on the forward edge and one or two on each side BUT I cant get access to the screws on the back edge because the roof wont retract far enough.
I assume I need to remove the roof but I havent a clue how to do it. If someone could help out that would be great. Thanks bunch..
ps This is the small normal size sun roof.
nag is offline   Reply With Quote
Old 08-22-2004, 04:50 PM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
pull the rubber gaiters down on each side and then there should be 3 t25 torx bolts on each side which hold the glass in
DT
HELP!!! Sunroof Removal liltrig99 3-Series (E36) 19 04-16-2005 12:35 PM
Sunroof Noises Caused By Vibration. victorgallas 3-Series (E36) 0 01-20-2005 03:27 PM
sunroof problem? help!!! pherbolario 5-Series (E12,E28, E34, E39, E60) 4 12-30-2004 05:57 AM
Sunroof Removal 88'325 3-Series (E21, E30) 4 05-23-2004 01:02 PM
Help with Sunroof Removal Andrewsd1985 3-Series (E36) 2 03-08-2004 06:55 PM
