White Smoke - 740i 1998 - BMW Forum - BimmerWerkz.com
Old 09-25-2004, 08:43 AM   #1 (permalink)
gm3mtm is an unknown quantity at this point
My car - with 135,000 miles - has just started to burn oil. A bit of white smoke is coming out of the left (driver's side) exhaust. Do you have any idea what might be causing this? Hard to fix the problem?
Thanks!!
gm3mtm is offline   Reply With Quote
Old 09-25-2004, 10:55 AM   #2 (permalink)
325isBaby's Avatar
Car: 2005 330xi
If it's white smoke that sounds more like coolant than oil....Oil burns off blue smoke. if it's white (coolant) then probably a head gasket...if it's blue (oil) could be rings, valves/valve seats, etc.
Come see me at MySpace
Old 10-01-2004, 08:13 AM   #3 (permalink)
Many of our Bimmers emit white smoke at idle and it seems to be temperature and humidity related, my 1988 750 does this band I burn no oil or lose any coolant.
White smoke comming out of engine bay kc740i 1,6,7,8 - Series and Mini Cooper 8 12-03-2005 10:10 PM
325i white smoke and idle problem puppie 3-Series (E36) 3 10-22-2005 07:57 AM
White Smoke Coming Out Of A/c in_si1ence 3-Series (E36) 9 08-22-2005 01:22 PM
540i And White Smoke HardStep 5-Series (E12,E28, E34, E39, E60) 3 02-22-2005 10:12 AM
