Whinning from console - BMW Forum - BimmerWerkz.com
Old 11-24-2003, 10:58 AM   #1 (permalink)
DaveBeck is an unknown quantity at this point
Hi Group.
I've a 2001 740il. When I run with the A/C on I have a whinning noise. It stops when I turn off the A/C. The dealer says this is normal. I don't understand how a car that sells for $70K new can have that noise.
Has anyone had this problem? I cannot find any TSB on it.
Thanks
DaveBeck is offline   Reply With Quote
Old 11-24-2003, 11:19 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
sounds like your auxilery fan making too much noise, what does it sound like under your hood with the a/c on and off?
Old 11-30-2003, 05:03 PM   #3 (permalink)
I had the auxillary fan replaced because it was noisey. The whining goes away when the a/c is turned off and comes back when turned on.
Thanks
Old 12-03-2003, 10:40 PM   #4 (permalink)
jyep's Avatar
jyep is an unknown quantity at this point
maybe it's the stepper motors which control the air directional flaps of your auto temp system. Been told this is a common problem with BMW 7 series. Will need to remove the entire dashboard to get to these motors.
<img src='http://img.photobucket.com/albums/v77/jyep1/nawz.gif' border='0' alt='user posted image' />
www.ownster.com (where bmw owners can talk shit)
jyep is offline   Reply With Quote
Old 12-05-2003, 03:01 AM   #5 (permalink)
stonecutter is an unknown quantity at this point
Interesting,
I just dropped of my 2001 740i at the dealership for the same reason. The repair guy said it was a bad a/c compressor.
stonecutter is offline   Reply With Quote
Old 12-05-2003, 05:55 AM   #6 (permalink)
DesmoBob's Avatar
Originally posted by stonecutter@Dec 5 2003, 12:41 AM
Interesting,
i'd get a second opinion if that repair guy said the compressor was causing that sound. while the compressor may indeed be bad, that is most likely a separate problem.
if the compressor simply fails, you'll just get warm air, no whining sound. if the compressor bearing fails, it will be more of a grinding or metallic scraping sound.
Old 12-06-2003, 06:58 AM   #7 (permalink)
ex owner/admin
Furious's Avatar
you guys have to tell your wives to get there heads out of the console, i mean come on how much whinning and nagging can one woman do!? :lol:
seriously desmo is right the compressor is the most expensive fix in the realm of a/c lots of mechanics ultimately try to sell you on this. believe me ive seen lots of cars come in with a new compressor and that customer wants us to fix the original problem because they hate the dealer for ripping them.
'95 318i instrument console lighting problem dublin95 3-Series (E36) 12 12-02-2005 11:23 AM
What's A "later Style Center Console Frame"? frank3 3-Series (E36) 2 04-20-2005 01:24 PM
Center Console Jammed Shut dclaw 3-Series (E46, E90) 0 04-19-2005 03:10 AM
Climate Control Console destro888 3-Series (E36) 10 11-10-2004 07:38 PM
Cracked Center Console on my 540i LetsPlayPDX 5-Series (E12,E28, E34, E39, E60) 5 09-03-2004 03:54 PM
