water pump - BMW Forum - BimmerWerkz.com
Old 08-27-2008, 09:33 PM   #1 (permalink)
Car: 94 740il
oted is on a distinguished road
water pump
740il i have put the new water pump back on with the new gasket that has that rubber seal built into it. put all the bolts on started it up and the bottom bolt leaks ,tightened it still leaks, should i take it all apart and put permatex this time
oted is offline   Reply With Quote
Old 08-27-2008, 11:07 PM   #2 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
Yes.....use just enough to hold the gasket in place & make sure both surfaces are clean, & be sure it does not shift out of position.
johnny,
Old 08-30-2008, 10:26 AM   #3 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
my 2 cents worth:
check and see that the new waterpump mating surface isnt warped. I have seen some new waterpumps that were defective out of the box. If it is good, then yes, permatex will help.
Good luck.
E38 98 or under water pump for non water cooled alternators brand new AlpineSixAndSeven OEM Parts 0 10-12-2007 03:58 PM
540 - Water Leak - Radiator? Exp Tank? Water Pump? windarra 5-Series (E12,E28, E34, E39, E60) 2 06-09-2006 10:13 PM
water pump again bimmer3214 3-Series (E36) 9 01-26-2006 09:03 PM
Water Pump rb26 1,6,7,8 - Series and Mini Cooper 1 06-12-2005 09:52 AM
Water Pump '93 93 325i 3-Series (E36) 5 09-22-2004 01:23 PM
