Vibrating steering wheel - BMW Forum - BimmerWerkz.com
Old 06-28-2008, 07:37 AM   #1 (permalink)
Beemerguy 32's Avatar
Beemerguy 32 is on a distinguished road
Hi Guy´s, having a problem with my front wheels vibrating around 40mph, should be just to re-balance the front wheels, right? Problem is that it´s not every time i drive the car it appears. So, could it just be the bushing..? Solution anyone..?
Beemerguy 32 is offline   Reply With Quote
Old 06-28-2008, 09:21 AM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Lightbulb
have the tires dynamically balanced first.
If the vibration doesn't go away; next place to look is tie rod ends, and then alignment... in that order.
Old 06-28-2008, 02:44 PM   #3 (permalink)
Ok, sounds right. Not cheap busings in the front thow, however i´ts a cool car so what the hell..
Old 06-28-2008, 06:42 PM   #4 (permalink)
She Vibrates
These cars are known to have upper control arm (thrust) bushing issues and the symptom is vibration at low speed. In my case I bought some control arms with new ball joints and urethane bushings already installed (BavAuto) and that solved my problem ('88 750il).
Old 06-29-2008, 03:40 PM   #5 (permalink)
I think youre right. Found out that the left shock is leaking too, and the bushing to the suspention strut is a gonner. So, i know what i´m doing on my holiday..
E39 steering wheel controls on a E36 steering wheel? jm1133 3-Series (E36) 13 12-27-2010 07:34 PM
Steering Wheel Upgrade! Best Sports Wheel for the E36? (judge pictures) Delmarco 3-Series (E36) 14 09-12-2005 05:59 PM
Vibrating Steering Kersi 1,6,7,8 - Series and Mini Cooper 2 12-15-2004 06:51 AM
Steering Wheel / Steering Feeling {|nf3rn0} 3-Series (E36) 0 10-21-2004 03:23 AM
Occasional Vibrating Steering Wheel gabeshmabe 3-Series (E36) 7 07-13-2004 09:12 AM
