Valve Question - BMW Forum - BimmerWerkz.com
Old 06-15-2005, 10:56 PM   #1 (permalink)
mrclean is an unknown quantity at this point
when I pulled off my valve cover on my 735i , I got under there and found that some of them were out of spec, but nothing to crazy, so I adjusted them. Anyway, after putting them all in spec .012 I believe is what my chilton's said, it still didn't get rid of the bit of valve clatter. Is the valve train on the M30 just noisy? It looked like everything was allright, no warped cam lobes or bad valves or anything, so is it just a little noisy?
mrclean is offline   Reply With Quote
Old 06-16-2005, 12:13 AM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
I set them at .011 which helps with the clatter and will also boost performance a slight bit. It does make the idle a lil more rough and as you know these 3.5s dont idle all that well to begin with.
DT
DT
Old 06-16-2005, 09:29 AM   #3 (permalink)
Good to know I'm not gonna suck a valve through or something. Yeah, it is a tad rough, but hey, what can you do?
New To Board, New 540i, Valve Gasket Question midi 5-Series (E12,E28, E34, E39, E60) 6 01-03-2006 10:25 PM
HELP..!!!.....removal of air pulse valve from e21 323iguy 3-Series (E21, E30) 0 09-06-2005 12:37 AM
Just got my 320i: Small question harpax 3-Series (E46, E90) 18 06-17-2004 04:24 PM
318ti ABS Hydraulic valve resistor readings retirednow 3-Series (E36) 0 06-08-2004 08:29 PM
info center in the gauge cluster question audiosolstice 1,6,7,8 - Series and Mini Cooper 3 04-30-2004 02:58 AM
