valve chatter - BMW Forum - BimmerWerkz.com
Old 11-26-2005, 03:09 PM   #1 (permalink)
kc740i is on a distinguished road
valve chatter
Hearing a ticking noise that appears to be comming from the left side of the engine. It sounds to me like valve chatter, but i am no mechanic. IT doesnt seem to go away when driving. The oil / spark plugs were recently changed, and i did not hear this noise before then. Any suggestions on what may be going on?
Oil ; Catrol GTX 10w-40
Spark plugs ; Bosch F 7 LDCR
Any suggestions would be appreciated thx.
kc740i is offline   Reply With Quote
Old 11-26-2005, 03:51 PM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
check to make sure all the spark plugs are tight, when loose they can make a ticking sound or an exhaust leak type sound. If that doesnt do the trick use a stethescope or a long screwdriver as a listening device to try and narrow down the noise. What weight oil were you running before and what climate do you live in?
DT
DT
Old 11-26-2005, 09:30 PM   #3 (permalink)
im not sure what weight it was before, it was mobil 1 synthetic. I will checkout the spark plug suggestion, i didnt hear this noise before so thats most likely what it is. I live in Florida. I am really hoping that its just the spark plugs and not something serious.
Thanks
1998 318is - Adjusting valve gear? alex_318is 3-Series (E36) 3 09-18-2005 04:48 PM
Valve Question mrclean 1,6,7,8 - Series and Mini Cooper 2 06-16-2005 09:29 AM
Governor Valve TrannyTrubl 3-Series (E21, E30) 2 05-24-2005 07:16 AM
Crank Case Ventilation Valve Kissner 3-Series (E36) 1 03-07-2005 08:10 PM
Clutch Chatter (grabbing) In First Gear 318is Mario Milewski 3-Series (E36) 1 02-22-2005 12:39 PM
