update gearbox,how? 2001 740i stuck in drive,after accident,help
i have a 2001 bmw 740i
and i purchase the car,,damage in front,,i fixed the car but dont want to start,,
i so that on the dash when i put my keys and turn ,,is on " drive (at dash light)
,,but in between chairs is on parking,,
and someone told me that i need to update my gearbox,,
Get a diagnostics carried out first, that may let you know what the problem is, it may just be the switch, as for an update if its an E38 no point as thats the last year they were made if its an E65 it can be updated but only at main BMW dealer.
how do i diagnose the problem?,,i did with a obd2 scanner and have no error codes,,or take it to a shop?
one guy said on this forum about the gearbox this:
"""To reset the computer is simple.....Disconnect the positive and neagtive from battery and cross these two wires, (with a screwdriver, or another wire) as long as the pos and neg are attached. Then open the ignition swith for 10-20 mins, re-connect the battery and the ecu is reset to default..."""
maybe this a one problem,,because after the accident ,,the computer thimks that the care is in drive,,so maybe a computer reset will fix that proablem,,need to try ,,but scare not to fry the computer..!?
I think your selector switch has malfunctioned..... It is mounted on the side of the trans I believe... Go under the car and check. Also does the light on the guage cluster move at all when ou move the shifter?
1992 318i Coupe parts car
yes the light on the gauge cluster moves,,when i move the shifter!
Dude it looks like it got knocked out of adjustment! It is bolted to the side of the trans try loosening it and adjusting it
you think so,,from that accident,,can get knocked out,,maybe thats why the shifter with the gauge are not the same?!,,will have to take a look,,
this here does it look the same? here
i have to find witch one is it,,
If it is a hard hit I could see that or if after the accident someone Forced the shifter into park and forced it outta adjustment. Yep that is the part!
Its easy to adjust, a bolt with a cable running through it.
Edit:
The switch in your link is accessible from above, ASAS I thought you were talking about the selector on the side of the box with the Bowden cable running through it ?
i took the cable out from the shifter and turned thowrds the engine,the shifter, and i did turn my key ,,and i can cranck the engine,,
i did not started yet because im still working on the body and arownd the engine,,,also found pass side the engine braket,support broken,,and the tranny suport broken,,(at the end of trany!)
man ,,that when you buy a car that was into a accident,,,
