Uneven Front End - BMW Forum - BimmerWerkz.com
post #1 of 5 (permalink) Old 10-16-2009, 05:25 PM Thread Starter
jrgordie is on a distinguished road
Uneven Front End
My driver side front is 1/2" higher than passenger side. I did change the coil springs on both sides and its still is uneven. Is this normal? Any ideas?
1998 740IL
jrgordie is offline
post #2 of 5 (permalink) Old 10-16-2009, 05:26 PM
Millions of them.
Torque's Avatar
Quoted: 1 Post(s)
Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute
I believe ride height should be measured with the car loaded up with weight equal to two people in the front, one in the back and full tank of gas.
Some variation is ok; im not sure that much should be though. I know on e36, up to 10mm difference is allowed.
Torque is offline
post #3 of 5 (permalink) Old 10-17-2009, 04:06 AM
Help from over the pond
marti5's Avatar
1/2" is nothing....you have to have these beasts dead level to measure them properly, as use a spirit level on both cills....and front a rear bumper...which is very hard to accomplish unless your work shop floor is spot on, that's the only way you can do it properly...So I would say the half inch difference is due to the car not being spot level, plus the tyre pressures have to be spot on all four wheels and if one of your rear springs is just slightly more worn than the other this will also put out the measurement as these beasts do twist slightly especially around roundabouts and corners...this can be eliminated to a degree by fitting a strut brace across the front suspension towers, but then you will have to have a full lazer wheel alignment undertaken and tracking..
marti5 is offline
post #4 of 5 (permalink) Old 10-17-2009, 07:23 AM
Millions of them.
Torque's Avatar
Quoted: 1 Post(s)
btw the proper way to measure is top of the wheel arch to the bottom of the wheel;
Torque is offline
post #5 of 5 (permalink) Old 10-17-2009, 09:40 AM
marti5's Avatar
I 2nd ^ that, just to clarify: middle of the arch to the bottom of the outer rim.
marti5 is offline
  BMW Forum - BimmerWerkz.com > BMW Model Specific Forums > 1,6,7,8 - Series and Mini Cooper
E36 coupe front end and four door front end... saylee 3-Series (E36) 6 01-19-2009 05:00 PM
86 325 front end to a 90 325 front end is that possible??? Skatebline 3-Series (E21, E30) 14 04-03-2006 11:08 AM
Front End Re-build RedbeautyIS 3-Series (E36) 1 04-16-2005 12:49 AM
Front end of my M3 getting fixed Slvr e39 M-Series (M1, M3, M5, M6) 5 05-25-2004 08:14 PM
front end alignment??? tknesek 1,6,7,8 - Series and Mini Cooper 1 04-24-2004 12:29 AM
