Tranny Gear Oil / Gearing Differences - BMW Forum - BimmerWerkz.com
Old 04-11-2005, 09:09 AM   #1 (permalink)
slyhog-22056's Avatar
slyhog-22056 is an unknown quantity at this point
Send a message via Yahoo to slyhog-22056
Recently I replaced the 5 speed in my 633 CSi with a Getrag 260 010 091.
The old one was a 260 010 090.
Well, first in the mornings (mid 60*s) it grinds the synchro's going into 2nd gear and snaps going into 3rd. until it warms up. I put 85W-140 gear oil in it and wondered if this is the correct oil.
Second, the gearing in this tranny is higher, I will need to go to bigger tires and wheels for the speedo to read correctly, it is off by 7 mph @ 70. I dont know what size tires were on the car I got the tranny out of, they were gone.
Mine are 24" in diameter, How much taller do I need to go??? I know I will have to go to a 15" wheel already.
<a href='mailto:slyhog-22056@sbcglobal.net'>slyhog-22056@sbcglobal.net</a>
<span style='font-family:Impact'><span style='colorurple'>Wm. D. Cunningham</span></span>
My 1984 BMW 633 CSi Pictures:
http://www.roadfly.com/bmw/gallery/p...37076,1;-24,1;
slyhog-22056 is offline   Reply With Quote
Old 04-11-2005, 01:50 PM   #2 (permalink)
njtech is an unknown quantity at this point
should be ATF, NOT gear oil in the trans.
njtech is offline   Reply With Quote
Old 04-11-2005, 03:06 PM   #3 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
[snapback]330156[/snapback]
redline fluids kicks ass. it will produce more whp vs the std. fluid.
it definately did when i had my tranny flushed and filled with their fluid. i'd highly recommend it if you can afford it (when i had my autotranny flushed it took 16 qrts at $9/qrt)
and having the speedo be off from the actual speed isnt irregular
my e30 is exactly 7mph off. i know because i drive by a radar unit everyday on the way to work and it always registers 7mph under what my speedo says im going. I have 24" tires, which are the factory size (195/65/14).
Whats 5 speed tranny gear ratios on 89 325i Slow325i 3-Series (E21, E30) 3 11-13-2005 08:11 PM
2001 330 Ci Tranny Problem (Reverse Gear) Need Advise texasjoe 3-Series (E46, E90) 11 11-09-2005 12:45 AM
Buying 740iL Sport. Tranny differences??? Bread Bimmer Talk/Motorsports Talk 2 06-27-2004 04:34 AM
Tranny Fluid and Rear gear oil Questions... BMWStrat 3-Series (E36) 2 03-23-2004 03:33 PM
