Tail Light Problem - BMW Forum - BimmerWerkz.com
Old 09-27-2008, 10:23 PM   #1 (permalink)
Klaus is on a distinguished road
Tail Light Problem
Hello. I'm new to this site and the world of BMW. I just became the proud owner of a 1988 735i, that has been in the family forever and is in remarkable original condition. One problem though that has me stumped. The tailights go out after about 1o minutes and I can not find any bad connections etc. Signal lights, brake lights and emergency flashers continue to operate. Fuse looks OK and lights will come back on after being off for a while. Anybody have any ideas as where to look?
I would hate to have to go to the dealer.
Thanks,
Klaus
Klaus is offline   Reply With Quote
Old 09-27-2008, 10:32 PM   #2 (permalink)
I think I might start with the headlight switch.
Old 09-28-2008, 04:38 AM   #3 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Are you sure there is no corrosion in the rear light cluster where the bulbs fit in??, if ok there make sure all the earths are fine in the trunk around the clusters, If ok check tightness of connector block on the rear of the switch, check the fuse has a good contact, if all that fails then go for the switch itself.
Old 12-20-2008, 12:26 AM   #4 (permalink)
jrockstangs's Avatar
jrockstangs is on a distinguished road
i have the same problem...only the tail lights and parking lights... its fine and then all of a sudden the light comes on stating that the tailights and parking lights are out...let the car sit for a few and then its good to go again....i think im gonna go with the fuse suggestion cause the fuse thats in there is kinda loose feeling hopefully thats it
jrockstangs is offline   Reply With Quote
Old 12-20-2008, 10:12 AM   #5 (permalink)
rickrhino is on a distinguished road
I had taillight problems with my 1995 740i. I replaced bulbs and cleaned connections for a year before I finally bought a pair of aftermarket replacements on ebay. Installation was really easy and they fit and work perfectly. Nice updated look too. $100. including shipping.
rickrhino is offline   Reply With Quote
Old 12-22-2008, 08:44 AM   #6 (permalink)
Smile Tail Light Problem
I would like to thank everyone for their suggestions. I worked my way through them and in the end it ended up being a faulty relay($110 Can.). My local garage hunted the problem down after I had tried everything else, including headlight switch. They only charged me 2 hours labour ($80 per)although it took him over 3 hours with the use of my wiring diagram.
Thanks again everyone.
Klaus
Old 12-22-2008, 09:07 AM   #7 (permalink)
Very glad that you found a solution to your issue!
Old 12-22-2008, 09:28 AM   #8 (permalink)
jimmythepie's Avatar
Car: 98,328i
do you have any pics of the car?
jimmythepie is offline   Reply With Quote
Brake Light Circuit And Tail Light Failure 325is1994 3-Series (E36) 7 08-05-2008 12:00 PM
1990 735i Tail Light problem razimm 1,6,7,8 - Series and Mini Cooper 0 11-08-2007 08:49 AM
Heated Seat And Tail Light Problem MadBMW M-Series (M1, M3, M5, M6) 1 03-17-2005 08:54 PM
A Little Tail-light Problem HCoPymp1011 3-Series (E36) 1 12-21-2004 06:11 PM
330CI LED Tail light conversion problem kwoktoa 3-Series (E46, E90) 2 02-05-2004 07:47 AM
