Suspension Bleed - BMW Forum - BimmerWerkz.com
Old 12-17-2004, 05:07 AM   #1 (permalink)
keithslippery is an unknown quantity at this point
hi guys.
i have just replaced the high pressure level hose on the suspension on my 1990 750il.
the self levelling suspension was working fine until pipe burst.
i lost most of the fluid while changing hose and have refilled with 7.1.
jacked rear of car up and started and lowered it down slowly to bleed as in the bentley way.
it took just under two cans of fluid.
but now the suspension switch light doesnt come on and the suspension doesnt some to change.
is there maybe still air in the system causing problems or could there be another way of bleeding.
or is it maybe more problems.
keithslippery is offline   Reply With Quote
Old 12-17-2004, 06:38 PM   #2 (permalink)
When you say you bled the system via Bentley by raising and lowering, did you also take the lid off of the PS Reservoir, fire the engine, and turn the steering wheel lock to lock two or three times?
Old 12-18-2004, 03:58 AM   #3 (permalink)
yes i did all this
Oem M3 Suspension Vs. Uuc Sachs Suspension 98three28i 3-Series (E36) 4 07-11-2005 04:31 PM
E36 Suspension Work, Want To Upgrade Suspension? victorgallas Product Reviews 8 02-08-2005 08:21 AM
Suspension Hints astral_tx 3-Series (E36) 27 08-15-2004 04:48 PM
FS: complete DINAN suspension STAGE 3 for e36 M3 seriousness Classifieds Sell & Buy 5 07-16-2004 07:19 PM
