Starting 740i 1998 - BMW Forum - BimmerWerkz.com
Old 09-26-2004, 02:48 AM   #1 (permalink)
gm3mtm is an unknown quantity at this point
Start
Battery ok>
When i turn the crank all i get is a clicking>
Bad starter??
THANKS!!
gm3mtm is offline   Reply With Quote
Old 10-02-2004, 11:38 AM   #2 (permalink)
I would still vote for the battery, it may have a good static charge, but not retain enough current at start to turn the engine over. I would first try to jumper her and see if that works. or with engine off, hook a volt meter up between B+ post and ground and take a reading (should see at least 12 VDC) then with the volt meter still hooked up, have someone try to crank her over and watch the volt meter and if she drops much below 12 VDC, then the battery is not well.
Old 10-24-2004, 07:40 AM   #3 (permalink)
jyep's Avatar
jyep is an unknown quantity at this point
don't forget to check out your alternator, bad alternator does not charge your battery while car is running, eventually your battery dies; car doesnt' start; happened to me.
<img src='http://img.photobucket.com/albums/v77/jyep1/nawz.gif' border='0' alt='user posted image' />
www.ownster.com (where bmw owners can talk shit)
jyep is offline   Reply With Quote
A Lot Of Hot Air - 740i 1998 gm3mtm 1,6,7,8 - Series and Mini Cooper 0 07-27-2005 02:29 PM
1998 740i Fully Loaded: $13500 Obo!!! Sean@Jlevi SW Classifieds Sell & Buy 1 03-20-2005 06:01 PM
Fuel Trim Malfunction - 1998 740i gm3mtm 1,6,7,8 - Series and Mini Cooper 1 08-13-2004 12:53 PM
7 Series Heat Stays On - 1998 740i gm3mtm 1,6,7,8 - Series and Mini Cooper 1 05-31-2004 12:57 PM
Red Airbag Light ON - 740i 1998 gm3mtm 1,6,7,8 - Series and Mini Cooper 1 05-31-2004 08:38 AM
