Smoke At Startup - BMW Forum - BimmerWerkz.com
Old 10-31-2004, 08:40 PM   #1 (permalink)
kyle is an unknown quantity at this point
I have a 98 740IL with 111,500 miles on it and it just started smoking real bad at startup. It will not do it after the first 10 to 15 seconds and doesn't seem to burn any oil. I thought I might have a bad plug but replaced them all and it still does it. It also just started idleing a little rough. Just slightly though. Does anybody know what may be the problem??
kyle is offline   Reply With Quote
Old 11-02-2004, 02:28 PM   #2 (permalink)
///Matt's Avatar
Sounds like you may have a cracked/worn head gasket. At statrup the gasket expands from the heat which would cause the leak to stop. Check with your mechanic and look at any fault codes that it sends out. Good luck...
White smoke comming out of engine bay kc740i 1,6,7,8 - Series and Mini Cooper 8 12-03-2005 10:10 PM
325i white smoke and idle problem puppie 3-Series (E36) 3 10-22-2005 07:57 AM
Smoke pollyo 5-Series (E12,E28, E34, E39, E60) 0 03-27-2005 08:16 AM
540i And White Smoke HardStep 5-Series (E12,E28, E34, E39, E60) 3 02-22-2005 10:12 AM
Check engine and smoke in the crank case Skipjacks M-Series (M1, M3, M5, M6) 8 07-29-2004 02:43 PM
