Shimmy & Shake At 45-60mph 93 740i - BMW Forum - BimmerWerkz.com
Old 01-18-2005, 12:12 AM   #1 (permalink)
robob69 is an unknown quantity at this point
Send a message via Yahoo to robob69
Smile
I have a 1993 E32 740i that I have a vibration at speeds of 45-60 Mph, I have had the tire rotated and balanced twice and it is still there, any ideas? ghead
Thanks
Robert
Houston, Texas
<span style='font-family:Courier'>Robert</span>
Houston,Texas
robob69 is offline   Reply With Quote
Old 01-18-2005, 12:54 PM   #2 (permalink)
///Matt's Avatar
The steering bushings are trashed. This is a very common problem. BMW has lacked somewhat in their design which causes the steering bushings to wear/warp pretty badly. I would reccomend having them at least checked out. They really aren't too expensive to r&r. I've replaced 3 sets now on my fleet, and they had the same symptoms as yours. Good luck!
Old 01-18-2005, 11:40 PM   #3 (permalink)
Unhappy
Thanks for the advise... I will look into it and I hope this helps..
Thank you again
Robert
Houston, Texas
Houston,Texas
Old 08-18-2008, 05:40 PM   #4 (permalink)
Car: 1993 BMW 740i
mrred7 is on a distinguished road
wash inside of rims
I have found the same problem in my '93 e32. I found that if you completely wash the inside of the rims with a pressure washer that it will fix the problem. Take off the rims and bring them to your local D.I.Y. car wash with a pressure washer, wash them thoroughly and then take them to a good tire place to get them balanced. You will also want to use steel wool where the rim sits on the brake rotor to remove any excessive rust that has caked on there over the years.
Jason
mrred7 is offline   Reply With Quote
Old 09-12-2008, 03:11 PM   #5 (permalink)
Vibration
If none of the prior suggestions work I would look at the upper control arm (thrust) bushings, this is another problem with our cars, I had the symptom you have on my '88 750 and replacing the bushings (I replaced the control arms which have ball joints and bushings attached) solved the vibration issue.
Old 09-12-2008, 08:25 PM   #6 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
Dude's this thread it from 2005.... And On the e32 a 55-65 Shimmy normally is Caused by the Thrust Bushings or the Control arm bushings Could be a whlle outta balance normally cleaning it doesn't help at all and Could actually make it worse if you hit the bushings with a pressure washer as it can tear the already damaged Rubber....
1992 318i Coupe parts car
I am Captain Obvious
Old 09-13-2008, 09:13 AM   #7 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Shimmy
All explained here:
BMW E32 50MPH - 60MPH SHIMMY
Old 10-03-2008, 01:00 PM   #8 (permalink)
740chp1211 is on a distinguished road
Mine has the same problem right now, i need the lower control arm, balljoint assy. it may not be the same shimmy, you may need somthing as simple as your wheels balanced, jack up the fornt end, and move the wheel, back and forth, up and down to check for play. and let me know what you get.
740chp1211 is offline   Reply With Quote
2001 740i navigation on a 98 740i bmw. nap21 Audio and Electronics 4 11-09-2004 05:31 PM
A Ghost in my front end... Name: Shimmy Spector mathetas 3-Series (E36) 3 08-27-2004 10:47 PM
Ghost Haunting Front End: Shimmy Spector mathetas 3-Series (E36) 1 08-26-2004 08:40 PM
