rough running at 20-30 mph - BMW Forum - BimmerWerkz.com
Old 03-16-2004, 10:25 AM   #1 (permalink)
duece is an unknown quantity at this point
Anyone have any experience with this. It's a 98 740 IL, 4.4, auto, 86K miles.
Seems to struggle if I just cruse along at this speed. It I get on it, it runs just fine. Have been to the dealer twice and they are stumped.
Help please....
Duece
duece is offline   Reply With Quote
Old 03-16-2004, 06:59 PM   #2 (permalink)
EXtech's Avatar
couple of things to check out.
1) Vacuum leak - vac. hoses, intake manifold gaskets, intake hoses, crankcase vent valve
2) Catalytic converter(s)
My bet is that you need to replace the crankcase ventvalve and do a complete intake manifold reseal. Do you ever hear a honking or groaning type of sound? One easy way to test for a bad crankcase vent valve is by letting the car idle in park, raise your hood and pull the engine oil dipstick. Many times this will cause the valve to start making noises.
However my second bet (a very close second) is one or both of your catalytic converters. with 86K miles on the clock it wouldn't surprise me either.
There could even be a chance that both are the culprit or neither are.
check this link out http://www.bmw-forums.com/forum/inde...showtopic=9451
its a post in this same forum about a 540 6spd
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 03-17-2004, 08:09 AM   #3 (permalink)
Thanks much for the reply! I will check these out and let you know.
Duece
Old 05-13-2004, 10:00 AM   #4 (permalink)
Well, they replaced the mass air flow sensor and it still runs rough at 30-40 mph.
It seems to be less noticable but it's still there.
I guess the cat's are next.
1985 735i Running Rough mrclean 1,6,7,8 - Series and Mini Cooper 15 11-12-2005 01:01 AM
Running Rough At 2000 Rpm Kswiss808 3-Series (E36) 8 02-01-2005 07:49 PM
E30 Running rough in 4th and 5th only cdruve 3-Series (E21, E30) 3 09-03-2004 06:27 AM
Rough running AndyBaloch 3-Series (E36) 5 08-11-2004 03:00 AM
rough running and no idea why.. mdaitc 3-Series (E21, E30) 1 06-19-2004 05:28 PM
