rear seat cushion replacement - BMW Forum - BimmerWerkz.com
Old 12-12-2003, 07:27 AM   #1 (permalink)
mistydakota is an unknown quantity at this point
I am having difficulty replacing the passenger side cushion back in its proper position. There seems to be too much resistance to slide back into place and I hesitate to try and use force. Is there a technique to doing this? The seats are power and heated. Any tips would be appreciated. This si my first BMW and it is a beauty. I am missing the manual info on the factory phone and radio. Any sources for me to check?
mistydakota is offline   Reply With Quote
Old 12-13-2003, 07:58 AM   #2 (permalink)
lwebb12's Avatar
Car: 2000 M5
lwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond repute
Send a message via AIM to lwebb12 Send a message via Yahoo to lwebb12
let me check my sources
Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
lwebb12 is offline   Reply With Quote
Old 12-13-2003, 08:07 AM   #3 (permalink)
lwebb12's Avatar
Car: 2000 M5
give me the last 7 of your VIN
Old 12-13-2003, 10:28 AM   #4 (permalink)
DC80532
Old 12-13-2003, 10:59 AM   #5 (permalink)
lwebb12's Avatar
Car: 2000 M5
Found on Roadfly
Lower rear seat removal instructions:
1. Turn on the ignition, move the elec right rear seat all the way forward.
2. Pull away the velcroed leather flaps between the upper & lower seats.
3. Remove the plastic cover on the edge of the seat that's between the seat & the car's body...push it towards the seat, then move up and out the gap created between the upper & lower seats.
4. Use a 17mm socket and 6" to 9" extension to remove the bolt holding the seat belt receptacle down. (you can see the bolt through the opening created by removal of the plastic fill piece in procedure #3.) DO NOT remove the plastic on the lower seat where the switches are...its' not necessary.
5. Raise the front edge of the seat up to release the clip. (its in the center of the lower seat at the forward edge. Locate the clip and push the button in the center...pull up and disconnect the electrical connector.
6. Now, you can remove the lower section of the rear seat. Raise up on the front of the seat while pivoting the rear of the seat downward. You need to do this to remove the rear tongs that go up into the guides in the upper part of the rear seat.
TIP: Take some time to look at how the lower section sits on the rails on the floor underneath the cushion and how the tongs are inserted into the upper rear seat back. WHY? Because when you go to put the seat back together you're gonna curse the day the German engineer who designed this abominable contraption was ever born! It can be done...it just takes patience and concentration.
Old 12-14-2003, 11:22 AM   #6 (permalink)
Thanks ever so much for the info. I will attempt the proceedure in reverse as the seat is propped up out of place looking for a home. Any ideas as to where I can get information on the telephone and radio operation. Radio works fine and the telephone is not a priority but I would like to satisfy my curiosity. By the way, I am German and I agree with you on the engineering: why do you think we lost two world wars.
Synthetic Oil and filter CiscoKid 3-Series (E36) 45 04-25-2007 10:50 PM
Rear Ball Joint Replacement Eric S. 5-Series (E12,E28, E34, E39, E60) 1 04-04-2005 11:50 AM
Empty Hollow Space In Rear Seat?? AIO 3-Series (E46, E90) 8 01-26-2005 02:24 PM
E39 525 Touring Rear Seat prozac 5-Series (E12,E28, E34, E39, E60) 1 11-07-2004 10:17 AM
Rear speaker replacement for e46 GnarlyCow Audio and Electronics 1 06-01-2004 08:44 AM
