| Your probably over heating the oil and creating detonition. You should get your cooling system flushed asap. avoid driving it or you could ruin your motor and create a much bigger problem. First check for coolant leaks and also check head gaskets. If you are mechanically inclined, take it to your mechanic.
|Dinan Intake|Schrick Cams|24lb Injectors|809 HFM|M50 Manifold|TMS Stage IV+|Dinan Strut Brace|Samco Hoses|UUC Pulley||UUC SSK DSSR|DDM Coilovers|Fikse FM10|Brembo Rotors|Hawk Pads|AA Exhaust|Alpine|Audiobahn|Sony| |
