radio does not turn on - BMW Forum - BimmerWerkz.com
Old 01-27-2004, 09:40 PM   #1 (permalink)
mybmauto is an unknown quantity at this point
The radio (including cassette etc.) in this 7 series does not turn on at all. We jumped the car a few days ago but don't know if this would caused a problem (everything else is fine). This car has navigation which is working. So we are told that radios with navigation do not have any codes. Any ideas or suggestions to get the radio going again? Would really appreciate it.
Thanks
mybmauto is offline   Reply With Quote
Old 01-27-2004, 11:25 PM   #2 (permalink)
TECH's Avatar
Check fuses. If it's an E38, there are fuses in the ebox under the hood, as well as some in the right rear of the trunk.
Old 01-28-2004, 08:18 AM   #3 (permalink)
Yes it is an E38. I checked the radio fuse under the hood and in the trunk. Both are good. I am told there is a fuse in the back of the radio unit. Is this true? and if so, is it easy to pull the unit out to get to this fuse?
Thanks.
Old 01-28-2004, 12:22 PM   #4 (permalink)
TECH's Avatar
I believe there is a fuse there, and that a 2mm or a 2.5mm allen should get it out.
Old 01-29-2004, 03:00 PM   #5 (permalink)
Could not find any fuses in the rear of the radio. Any other suggestions? thanks.
Old 03-03-2004, 02:32 AM   #6 (permalink)
Kjay is an unknown quantity at this point
Try taking a test light and making sure the constant wire and the switched wire have power.
Kjay is offline   Reply With Quote
Old 03-04-2004, 07:53 PM   #7 (permalink)
EXtech's Avatar
I would avoid using a test light on a BMW, especially late models. A multimeter would be a beter and much more advisable choice. Check your voltage on both sides of the fuses. Sometimes those fuses can look ok but are actually bad.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 03-28-2004, 12:16 PM   #8 (permalink)
1996BMW750iL is an unknown quantity at this point
What year is the car? There should be a fuse next to the wiring harness in the back of the reciever. Is this the three part radio (reciever, eq, & MID). I had some problems with my radio too. when you turn your headlights on, do the buttons iluminate? I thought i'd lost power, but this wasn't the case, it sees to have been some kind of software related malfunction. I'm not sure about the security system, but you might be able to restore function simply by removing and reinstaling the radion components. I'm not sure what else to think.
Noah
1996BMW750iL is offline   Reply With Quote
1997 528i Radio Doesn't Work Properly ozbmw 5-Series (E12,E28, E34, E39, E60) 4 04-17-2005 12:06 AM
Vanity Mirror Causing Radio Prob. dell 5-Series (E12,E28, E34, E39, E60) 1 12-14-2004 12:41 PM
1995 740i Radio / Audio System wmccally 1,6,7,8 - Series and Mini Cooper 1 04-19-2004 12:11 AM
turn signal blinker, radio noises trbotwuk 5-Series (E12,E28, E34, E39, E60) 6 02-09-2004 04:29 PM
Radio does not turn on mybmauto Audio and Electronics 2 01-28-2004 08:20 AM
