R & R Headlight Washer Nozzle??? - BMW Forum - BimmerWerkz.com
Old 01-06-2005, 05:48 PM   #1 (permalink)
tknesek is an unknown quantity at this point
I need to replace headlight washer nozzle on 2001 740il and I'm told I have to remove front bumper to do it. Any clues about how to?? Most engineering on this car seems much easier than that, I haven't found any clues yet on the internet.
Thanks for any help or leads. ghead
Terry
tknesek is offline   Reply With Quote
Old 01-09-2005, 07:11 PM   #2 (permalink)
TECH's Avatar
Terry
[snapback]265809[/snapback]
Take loose the left and right front inner fenderwells, attached to the bumper, and remove the triangle shaped trims under the front corners.....just a few 8mm screws...
There are 2 main bolts that hold the bumper on, just look above the grills in the bumper. Those are allen bolts. Get those out, and it slides off. Going back on, there are guides on both sides, make sure they go in or it won't fit right.
The jet comes off after you remove the hose, and one plastic nut.
Simple..........but I do it for a living.......
Old 01-09-2005, 08:49 PM   #3 (permalink)
Originally posted by TECH+Jan 9 2005, 07:11 PM--><div class='quotetop'>QUOTE(TECH @ Jan 9 2005, 07:11 PM)</div><div class='quotemain'><!--QuoteBegin-tknesek@Jan 6 2005, 05:48 PM
I need to replace headlight washer nozzle on 2001 740il and I'm told I have to remove front bumper to do it.* Any clues about how to??* Most engineering on this car seems much easier than that, I haven't found any clues yet on the internet.
Thanks for any help or leads.* * ghead
Terry
[snapback]267662[/snapback]
[/b][/quote]
Thanks a bunch, I will try it next weekend.
Terry
I Need A Headlight Prism Or Headlight 528man Classifieds Sell & Buy 0 04-06-2005 09:37 PM
'01 330ci, Headlight Washer Leak And No Trip Comp! davenicholls 3-Series (E46, E90) 0 03-11-2005 09:40 AM
Retractable Headlight Washer jeremer 3-Series (E46, E90) 12 01-28-2005 07:35 PM
Headlight washer pump aseaver 1,6,7,8 - Series and Mini Cooper 1 09-10-2004 08:12 AM
What are headlight eye lids acousticvan 3-Series (E36) 4 09-27-2003 08:37 AM
