Problems With Resetting Inspection Lights - BMW Forum - BimmerWerkz.com
Old 03-05-2005, 01:34 PM   #1 (permalink)
kyle is an unknown quantity at this point
I have a 98 740IL. I reset the lights exactly like it says with the 7 and 19 pin for 12 seconds. The lights reset but now the car misses real bad. THe mechanic says the sensor in the back of the engine that lets air into the engine to keep the engine pressure correct is bad.. Basically oil is being shoved up into the top end and into the cyliners which causes it to burn oil... Has anyone heard of this? If so Is it easy to fix myself?
kyle is offline   Reply With Quote
Old 03-05-2005, 06:17 PM   #2 (permalink)
Sounds like a PCV valve issue, go to roadfly.com and then to the correct board for your car, register (it is free) and search or post your issue and I bet someone can answer the question.
Old 03-05-2005, 06:56 PM   #3 (permalink)
Moderator
Dirty_Tool's Avatar
Bah! Why go to roadfly when the answers are right here!!!!! Search our archives, you will find this topic has been covered before right here. Basically your mechanic is telling you that your PCV plate is faulty and needs to be replaced. This is somewhat common on the BMW v8 engines. Check with him to make sure it doesnt need intake manifold gaskets replaced as well. It usually does. I dont see how this could have anything to do with you resetting your lights, prob just a coincidence. If you have any more questions let me know.
DT
DT
Old 03-14-2005, 04:43 PM   #4 (permalink)
I have not been able to find any topic concerning this in the forum. Any suggestions. The engine burns oil and runs rough. Fortunately I have another car to drive as this one sits in the garage. It had to of fried something because this is the second 740 I have done this to. Thanks for all of your help.
Old 03-14-2005, 06:04 PM   #5 (permalink)
just sounds like a bad crank case vent valve plate on the back of the intake. take it to a dealer and they can get it all fixed for ya.
Resetting The Inspection Lights mssoetaert 5-Series (E12,E28, E34, E39, E60) 1 08-19-2005 03:20 PM
