please tell me I haven't broke it - BMW Forum - BimmerWerkz.com
Old 11-28-2009, 09:44 AM   #1 (permalink)
Car: 1993 730i V8
mikeyb is on a distinguished road
I have recently bought a beautiful example of a V8 730i 1993 model with everything working just as it should, that is except for the waterpump where the bearings have gone and the fan is all wobbly and it loses water out the spindle. I am quite capable of doing this so set about it today armed with a new pump to fit. despite a few awkwardly located 10mm bolts (and god knows how I am going to get them back in) I succeded in getting the offending pump off; this is where I hope something bad has not happened.
When I was pulling the pump forward to remove it from two metal pipes that appreared to come out of the space under the air intake stuff, the larger of the two pipes detached itself from the other end. from what I can gather it seems to friction fit itself into a hole with a rubber seal. I think I have relocated it and it seems quite well seated and isn't wobbly but how can I tell???? I cannot see it because of all the intake stuff. has anyone experience of this? and can give me some good news
mikeyb is offline   Reply With Quote
Old 11-28-2009, 11:53 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Wish you would have asked how to remove first, but never mind, if you have relocated it as you say all will be fine,put it all back together, if it hasn't relocated correctly you will soon know and have to remove the intake manifold to do it properly, make sure when you put the new pump on you relocate the front ones correctly.....fingers crossed
Old 11-29-2009, 03:30 AM   #3 (permalink)
Car: 1993 730i V8
I read an article by someone on another site which was how I got to where I did. Unfortunately, the article neglected to mention these pipes. I shall assemble the water pump this morning and as you say "fingers crossed" hopefully it should be ok. If not then off with the intake stuff
Old 11-29-2009, 03:12 PM   #4 (permalink)
Car: 1993 730i V8
Well well well..... it seems to have gone OK...Filled up the cooling system with nice clean water (please tell me if I need to use some special stuff or will good old H2O with some antifreeze do?). I had a bit of a struggle with the bolt behind the crankshaft pulley but found that tying a piece of string to the bolt and dangling it combined with a long screwdriver seemed to make it very easy.
Old 11-29-2009, 03:27 PM   #5 (permalink)
AFAIK the best coolant mix is 50-50 antifreeze and deionized water.
Old 11-30-2009, 03:40 AM   #6 (permalink)
marti5's Avatar
Glad all seems well, as WS has said 50/50 mix with deionized water is this best way or just but ready mixed.
I broke it! Larry in Mesa 5-Series (E12,E28, E34, E39, E60) 5 11-01-2009 12:51 PM
I Think I Broke The Tranny flying_junk 3-Series (E36) 6 03-19-2005 11:31 PM
Well, I Broke Her Kevin325i 3-Series (E36) 33 01-04-2005 12:41 PM
Help....car Just Broke Down kkevin77 3-Series (E46, E90) 3 11-03-2004 10:28 AM
