over heating - BMW Forum - BimmerWerkz.com
Old 01-24-2009, 04:17 AM   #1 (permalink)
latreal is on a distinguished road
over heating
i have a 2001 740 il and it over heats when i get up to 60 m/hr but not all the time. could it be the radiator. it has radiator fluid in it and the only indications it get is from the dash when the temp rises.
latreal is offline   Reply With Quote
Old 01-24-2009, 05:03 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Could be many things, but only at 60mph strange, I would go for the viscous fan coupling, are you losing fluid?
After that, waterpump (check for leaks now),check hoses, radiator etc etc, a leak should leave a whiteish residue which is the antifreeze dried out.
Oh, how do you know you have fluid in the rad as you are unable to see in to the rad???
Old 01-26-2009, 01:08 PM   #3 (permalink)
Overheat
Overheat at 60 MPH points more to a water pump (IMO) that a visc ous fan clutch, in my case ('88 750) she would overheat a idle and be fine at speed, replacing the fan clutch solved that problem.
Over Heating dand65 3-Series (E46, E90) 6 08-06-2005 03:28 AM
Heating WarNox 3-Series (E36) 6 05-10-2005 10:51 PM
Heating disciplej 5-Series (E12,E28, E34, E39, E60) 2 02-28-2005 09:39 AM
Over Heating steveo34 3-Series (E36) 0 10-30-2004 02:29 AM
heating steveinwa 3-Series (E36) 3 10-25-2003 06:57 PM
