Noisy Engine 7 series - BMW Forum - BimmerWerkz.com
Old 03-23-2010, 10:27 PM   #1 (permalink)
slurat1958@aol.com is on a distinguished road
I have a 1999 740i with 135k miles. When I start up it sometimes has a rattle that gets worse as the engine gets hotter you hear it when it is idling. The sound seems to come from the front at the timing cover. I have read about the vanos unit needing to be replaced on other series but, I have heard mine doesn't have that. If that is the case could it be the timing chain components? Has anyone had this problem with a 7 series? I appreciate any info. Steve:
slurat1958@aol.com is offline   Reply With Quote
Old 03-23-2010, 10:34 PM   #2 (permalink)
You may wanna have the timing chain tensioner checked/replaced - and no driving before doing it. If the chain skips time, very bad things!
Old 03-23-2010, 10:57 PM   #3 (permalink)
Car: 1990 BMW 735iL
beamers4life is on a distinguished road
yes very bad things is correct talk about possibly bending/ breaking every valve in your motor trust me it take 1/20 of the time to replace a damn timing chain and gears and costs so much less than having to replace your valves and maybe your whole head
beamers4life is offline   Reply With Quote
Old 03-23-2010, 11:33 PM   #4 (permalink)
Thanks for the advice. I have been thinking that was the problem.
Old 03-25-2010, 06:49 AM   #5 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
A 1999 740i definitely has Vanos I think yours probably has single Vanos rather than double depends on the date of birth....
Old 03-29-2010, 10:51 PM   #6 (permalink)
Car: 1992 735il..500$ beater
kenjh is on a distinguished road
what is a vanos??
kenjh is offline   Reply With Quote
Old 03-29-2010, 11:10 PM   #7 (permalink)
Vanos is BMW's variable valve timing system.
Old 03-30-2010, 04:53 AM   #8 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
I am pretty sure that the dual Vanos appeared in the 1999 build 740, and is called the M62TU, Marti5 will correct me if I am off the mark.
Old 04-04-2010, 01:21 PM   #9 (permalink)
Car: 2001 740il
bricha2 is on a distinguished road
I have a 2001 740il and have the same rattling noise when the engine fire up from a cold start. Are there any technical document for a DIY job on replacing the chain and tensioner?
bricha2 is offline   Reply With Quote
Old 04-04-2010, 06:41 PM   #10 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
ummm... if i were the car owner:
I would instead take out the serpentine belt and start the engine and check if the sound persists.
at 135,000 miles. it is hardly likely that VANOS or timing chain & auxilliary components are at fault...
the rattle i.e. rapid succession of tick-tick-tick* that increases with RPM's just might be a faulty belt tensioner only although if & when you listen, it sound like it is coming from the timing cover.
I suggest you eliminate that first, before you suspect more complicated things
Old 04-14-2010, 01:23 PM   #11 (permalink)
basumarra1510 is on a distinguished road
hi !!!
its really a informative post...
thanks for your information ...........
basumarra1510 is offline   Reply With Quote
Future BMW 1-Series and 3-Series to Get Turbocharged 3-Cylinder and 4-Cylinder Engine administrator BMW News 6 05-16-2009 02:14 AM
E Series Engine adria 3-Series (E21, E30) 2 04-20-2005 10:27 AM
5 Series With New Engine The Pentium Guy 5-Series (E12,E28, E34, E39, E60) 3 11-16-2004 06:15 PM
New Engine On A 5 Series billB 5-Series (E12,E28, E34, E39, E60) 5 11-05-2004 10:12 PM
6-series engine swap icntspl 1,6,7,8 - Series and Mini Cooper 6 01-31-2004 10:05 AM
