No power to fuel pump - BMW Forum - BimmerWerkz.com
Old 09-17-2008, 09:39 PM   #1 (permalink)
sho_me is on a distinguished road
I have a '95 740il, it's not getting any power to the fuel pump. Does anyone know which relay is for the fuel pump? Which fuse I need to check in the trunk and underhood? Is there anything else that would cause the no power issue? thanks.
sho_me is offline   Reply With Quote
Old 09-18-2008, 09:02 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Hi, Is it an E38 or E32 ?
Old 09-18-2008, 06:58 PM   #3 (permalink)
It's an e38.
Old 09-20-2008, 07:52 PM   #4 (permalink)
And I don't have spark.
Old 09-21-2008, 11:24 AM   #5 (permalink)
marti5's Avatar
Ok.......... CMP ( camshaft position sensor ) could be at fault as if this has died you wont get fuel or a spark commonish problem, should be at the front of engine, somewhere around the bottom of the dip stick.
The fuel pump relay (K96) is located on the RHS of the luggage compartment near the battery and is the second from furthest rear. The relay and pump is served by fuses 17 and 57.
The fuel pump will not operate if the car is immobilised by the alarm system.........
Power for Fuel Pump Relay WJACOBS5 New Members Check In 0 09-12-2008 10:27 AM
No power to fuel pump SITAC 3-Series (E36) 6 04-06-2006 04:36 PM
Fuel Pump xxkr0nixx 3-Series (E36) 1 05-25-2005 12:53 PM
fuel pump tico481 3-Series (E36) 7 06-15-2004 01:58 AM
