New To Bmw's With Some Questions - BMW Forum - BimmerWerkz.com
Old 12-14-2004, 09:29 AM   #1 (permalink)
fredrex is an unknown quantity at this point
Hello,
I just purchased a 1990 BMW 735il. I am very happy with it, the car is sweet! But there are a few problems that I need help with.
1. The steering wheel tends to shake when I apply the brakes. And I feel the car lightly shaking back and forth.
2. When I was driving last night, the headlights shut off on a few occasion.
3 and finally, when I am driving everyone now and then I hear a light high whisper.
Does anyone know what is cause of these problems are?
fredrex is offline   Reply With Quote
Old 12-14-2004, 08:38 PM   #2 (permalink)
The tire bounces and the suspension is weak and just keeps bouncing.
The pulsations are most likely the thrust arm bushings.
OE was rubber and if sags it can cause the steering wheel to pulse 2 inches on brake application. Most use eurothane bushings that never need replaced. BMW came out with the 750i bushings requiring the installer to grind the bushing down to fit.
Here is a link to Paul Gray, Grunt, who makes a replacement for this bad deal.
http://www.gruntsbushings.com/index.html
Bad:
Thrust arms with new bushings installed.
Replace the k4 low beam relay.
I have no idea what you mean.
Later,
<img src="http://kcrealtime.com/dyno-max_900_hp.gif">
KC Ron Carter is offline   Reply With Quote
Buying First Used Bmw, Have Some Questions ynotony 3-Series (E36) 1 06-06-2005 03:17 AM
Whats So Good About Bmw's, I Need A Good Arguement BMW-ATI 3-Series (E36) 41 12-06-2004 08:50 PM
Noob Questions.... 92_325i 3-Series (E36) 1 10-01-2004 11:16 AM
E36 upgrade questions Q_BMW 3-Series (E36) 12 07-01-2004 08:12 PM
BMW 525i 1995 WAGON QUESTIONS vawheelerdealer 5-Series (E12,E28, E34, E39, E60) 3 01-28-2004 06:29 PM
