need some help with 740iL - BMW Forum - BimmerWerkz.com
Old 10-08-2009, 03:16 PM   #1 (permalink)
slidebabyslide is on a distinguished road
I bought a 96 bmw 740iL as a project, the clutch fan had come off and tore up a bunch of stuff including:
radiator and both hoses, expansion tank, and coolant sensor wiring.
It also broke the fan shroud and chopped up the power steering lines.
I have replaced everything except the coolant temp sensor wiring, and power steering lines.
It was running before I took it apart, and now it's not giving me any love.
When I try to start it, it says "key lock in ignition".
I've searched with no real results.
what do I need to do to fix it?
Thanks
slidebabyslide is offline   Reply With Quote
Old 10-13-2009, 07:29 PM   #2 (permalink)
cgerstner is on a distinguished road
Does it try to turn over at all? If not may sound funny but check the battery, maybe you left a door open, light on etc.
cgerstner is offline   Reply With Quote
Old 10-13-2009, 07:53 PM   #3 (permalink)
Got her running, thanks guys!!!!!!!!!
Old 10-13-2009, 08:03 PM   #4 (permalink)
Glad you got it sorted!
Old 10-13-2009, 09:21 PM   #5 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
So what was the fix that sorted out the problem?
Old 11-11-2009, 07:07 AM   #6 (permalink)
I traced my battery wiring, and there was a break in the ground wire close to the chassy.
A NEW PROBLEM!!!!!!!!!!!
I'm losing battery charge. I think the ignition has something to do with it because the fuse box under the hood has constant power, even with the key out of the ignition.
Any suggestions?
Old 11-11-2009, 09:52 PM   #7 (permalink)
Car: 1990 BMW 735iL
beamers4life is on a distinguished road
Im feeling like its the ignition switch itself has a loose tumbler or something do you have to jiggle the key at all to get the key in or trying to get it to start. Or does the key feel loose at all in the ignition. Check Autohausaz.com they are the cheapest oem beamer part distributor i have seen yet.
beamers4life is offline   Reply With Quote
Old 11-12-2009, 02:56 AM   #8 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
The tumblers are in the barrel, the switch is a separate module attached to the rear of the barrel and the contacts can become sticky causing a drain..
93 740il petrusob 1,6,7,8 - Series and Mini Cooper 1 08-30-2009 05:59 AM
95 740il sogio 1,6,7,8 - Series and Mini Cooper 3 07-20-2005 06:27 AM
94 740il ozzi2 1,6,7,8 - Series and Mini Cooper 0 05-01-2005 10:44 AM
95 740il sogio 1,6,7,8 - Series and Mini Cooper 7 03-13-2005 03:26 PM
740iL talonc4t 1,6,7,8 - Series and Mini Cooper 1 01-13-2004 07:49 PM
