Need help with bmw 750iL 88 model - BMW Forum - BimmerWerkz.com
Old 03-04-2006, 05:49 AM   #1 (permalink)
dark31 is on a distinguished road
Exclamation Need help with bmw 750iL 88 model
ive just bought a e32 750il with the m70 v12 in it. i wanna know how do u opperate the esm gearbox button. i just wanna know if mine is broken cause i cant work it. and in the airfilter box is the O2 sensor in it. cause i wanna change them for 2 pods. and ideas or is it better to just put a perfomance straight filter.
dark31 is offline   Reply With Quote
Old 03-04-2006, 06:22 PM   #2 (permalink)
1988 750
Well the E-S-M switch is pretty straight forward. In E, Econmy mode the car goes through all gears and ends up in Overdrive. In S (sport) the shift points are raised to give quicker acceleration. In M, Manual, you select the gear (1-2-3). Sliding the E-S-M switch will change modes and the mode will appear on your instrument cluster. If in any mode except E, pushing the depression in the center of the switch will take you back to E. The oxygen sensors are located in the catalytic convertors (they screw in) and you will need to drop the forward part of the exhaust system to access the sensors.
Junk Yards List USA SpeedInfusion Bimmer Talk/Motorsports Talk 19 09-12-2008 08:09 AM
E39 BMW M5,2000 UK Model mike M-Series (M1, M3, M5, M6) 1 09-17-2005 12:57 PM
what bmw model year is the most reliable and least problematic for the e30? träumer 3-Series (E21, E30) 4 09-14-2005 07:12 PM
