More Problems.. - BMW Forum - BimmerWerkz.com
Old 06-22-2005, 07:30 PM   #1 (permalink)
Uber-Pea is an unknown quantity at this point
So my check engine oil pressure light went on today. So I pulled over and checked my oil. I had about 3/4 so I filled it up with an extra quart. The light turned off for about 5 mins... then it came back on making a slight ticking sound in the engine.. any help please? thanks
Uber-Pea is offline   Reply With Quote
Old 06-23-2005, 04:44 PM   #2 (permalink)
Zulu95 is an unknown quantity at this point
I've seen this on other boards and it turned out to be a faulty pressure sending unit. I would start by replacing that and maybe sticking an oil pressure guage in to check the pressure.
Zulu95 is offline   Reply With Quote
Old 06-23-2005, 09:02 PM   #3 (permalink)
No it wasnt a sensor failure because the engine was running heavy and also it was making a slight ticking sound as if the engine was not getting enough oil. I drive a 95 740iL, could this maybe be the "Nikasil Issue"?
Climate Control Problems black318 3-Series (E36) 0 02-24-2005 02:00 AM
94 325is Problems sre2114 3-Series (E36) 23 10-21-2004 04:27 PM
cert pre-owned '01 330xi problems mcflier2 3-Series (E46, E90) 5 07-27-2004 03:24 PM
