i installed aftermarket rear tail lights, clear corners with silver bulbs(generic i believe), and redone top/bottom lenses. I get an error check corner light. My fog lights are not working properly either after i replace the lense. I custom painted the inside and removed the center plate for the foglights. I plugged it, turn it on but nothing turn on. Light bulbs was working before i did the mod/update. Im thinking it has to be the ground. I took a voltage tester and it had current coming out the plug but it wont light up the bulb =(
can anyone verify its a ground issue?
