| Mini Cooper Power Steering Does anyone know if it is possible to reprogram the Mini Cooper ECU to bring on power steering sooner and at narrower steering angles. For example, whenever the steering wheel is not in the straight ahead position. I know this should be based on the input data from the LWS-Steering Angle Sensor. I am wondering whether or not this is a programmable setting or not. Aftermarket pointers are also acceptable. Thanks. -- Joel |
