Help... Shopping for a 2001 740 IL - BMW Forum - BimmerWerkz.com
Old 07-15-2004, 03:48 PM   #1 (permalink)
fivestring is an unknown quantity at this point
Thumbs up
... I could use any and all help i can get with this one... this being my first BMW, i am a bit apprehensive... what are the more frequently found issues on this model? am i to look for something else? thanks...
fivestring is offline   Reply With Quote
Old 08-11-2004, 08:38 PM   #2 (permalink)
bschaber is an unknown quantity at this point
Not alot of help for you but after all my shopping I found that the 01 is not worth the extra dough. Find a 99 or 2000 with lower miles. I DID find these notes on common problems but nothing reflects the newer ones that body style hopefully because there are none. Not much help on this site though is there?
Trouble Spots
Air conditioner: The air conditioning may leak and one of the hoses was being replaced whenever the vehicle was in for routine service. (1995-96)
Automatic transmission: The automatic transmission will malfunction, and eventually fail, if the wrong transmission fluid is added. (1995)
Dashboard lights: The oil warning light may come on due to a faulty oil pressure switch. (1995-96)
Odometer: The trip odometer resets itself after about 650 miles. (1995-98)
Paint/body: Using the jack bends the rocker panel on 740i models and the jacks were being replaced whenever the car was in for other service. (1995)
Poor transmission shift: The transmission will not shift out of third gear if there is a difference in tire sizes caused by low air pressure, mismatched tires, etc. (1997)
Power seats: The power seats fail due to wires being chafed underneath the seat. (1995-98)
bschaber is offline   Reply With Quote
Old 08-12-2004, 02:00 PM   #3 (permalink)
lml99740 is an unknown quantity at this point
Having lived with a 99-740i Sport Package, model for the last 5 years I would encourage you to proceed with some caution on used purchases. Basic rules apply here, know the service history and inspect carefully. Stay away from an accident-repaired vehicle. I advised friends to consider a CPO model from a dealer with the 100k warranty; you will use the warranty on this car.
The vehicle is the top of the food chain for big luxury sedans. At 94K miles mine looks and drives like it was new. A Lexus does not hold up as well on the performance and feel but this model is no Lexus when it comes to repairs. You can expect tires to go quickly (every 25K miles), power steering hoses every two years, O2 sensors, sunroof wind noise, hood sensor and coolant level sensor to name a few. Brake rotors cannot be turned and must be replaced every other pad change. Little things can be costly, but the power train on this car has been flawless. I budget about $2K / year to keep it in top condition, and I do yearly fluid changes (brake, coolant).
I plan to drive it at least another 100K miles. There are just no other cars in its class that match the drive and performance. My only concern is the transmission life span. It is “sealed” with lifetime fluid. You will find varying opinions on if fluid changes should be attempted. If the transmission goes, the expense will be significant (mine shows no signs of wear, so far).
This car is one very safe, high performance vehicle. If you get a true sports package model beyond 99 you get stiffer, shorter springs, M parallel wheels, shadow line trim and a quicker differential, plus better seats. Happy hunting
lml99740 is offline   Reply With Quote
Old 08-13-2004, 04:19 AM   #4 (permalink)
gm3mtm is an unknown quantity at this point
Very expensive to maintain and always breaking down.
gm3mtm is offline   Reply With Quote
2001 330 Ci Tranny Problem (Reverse Gear) Need Advise texasjoe 3-Series (E46, E90) 11 11-09-2005 12:45 AM
Bunch of ?s - mainly Speaker Sizes for 2001 325ci OmarVelous Audio and Electronics 0 12-12-2003 01:57 PM
