Help with Reading - BMW Forum - BimmerWerkz.com
Old 10-08-2011, 09:02 AM   #1 (permalink)
card-dude is on a distinguished road
Help with Reading
I've been trying to work out the ABS and Brake lights that won't go off. Replaced the ignition switch thus far. I'm thinking my ABS Module needs to be rebuilt. Any advice would be greatly appreciated.
I had a friend run a full test and here are the results:
Brian's Short Test September 8 2011
Traction control
Current Fault Codes
32:
Wheel sensor front right
44:
Unkown fault code, please tell us about this missing information by clicking here
Transmission control
No Faults Found
Multiple restraint system 4
Current Fault Codes
1:
Ignition circuit ZK0 / Airbag driver stage 1
Electronic immobilise system (EWS)
Current Fault Codes
15:
Power on reset
16:
Key number 1 not valid because of wrong identification
Steering angle sensor (LEW/LWS)
No Faults Found
Lamp check module
No Faults Found
Automatic heating and air conditioning E38
No Faults Found
Instrument cluster
Current Fault Codes
145:
139:
Chime 3
144:
Clamp 15
191:
IKE-EEPROM error, coding incorrect or incomplete
146:
Central body electronics module 3 for E38, E39
Current Fault Codes
Radio (RAD)
No Faults Found
Multi-information display E38, E39, E53, L30
Current Fault Codes
1:
Invalid status response from IKE
Traction control
Current Fault Codes
32:
44:
No Faults Found
Current Fault Codes
1:
Current Fault Codes
15:
Power on reset
16:
No Faults Found
Lamp check module
No Faults Found
No Faults Found
Instrument cluster
Current Fault Codes
145:
139:
Chime 3
144:
Clamp 15
191:
146:
Current Fault Codes
Radio (RAD)
No Faults Found
Current Fault Codes
1:
The following modules were not found in the vehicle
Engine - M62(DME)
Rain / Light sensor (RLS)
Seatmodule (SM)
Cruise control
Tire pressure control (RDC)
Engine - M62(DME)
Seatmodule (SM)
Cruise control
card-dude is offline   Reply With Quote
Old 10-08-2011, 10:59 AM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
The clue is the top fault code listed (Wheel Sensor) !!
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 11-21-2011, 12:10 PM   #3 (permalink)
After replacing both front wheel sensors. the warning light CES came up and the reader showed P0500 (wheel sensor). So, I had the ABS module rebuilt for $150 and now ALL lights are off. Yea!
Old 11-21-2011, 01:54 PM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Well done mate... More satisfying eh? Big Smiles now ;-)
Eso es todo!
BMW Part Market
New Member ?
Tachometer reading is off! bimmerguy82 3-Series (E36) 5 12-29-2006 10:11 PM
OBC temperature reading Coolq 3-Series (E36) 7 12-04-2006 03:19 AM
Outside temp reading jon1282 5-Series (E12,E28, E34, E39, E60) 9 11-07-2006 02:52 AM
Outside Temp Reading jah5927 5-Series (E12,E28, E34, E39, E60) 8 08-29-2005 09:14 PM
Temperature Reading afrochapin 5-Series (E12,E28, E34, E39, E60) 2 04-12-2005 05:26 PM
