Help! My 740i Is Dripping - BMW Forum - BimmerWerkz.com
Old 12-12-2004, 10:25 AM   #1 (permalink)
abdoul is an unknown quantity at this point
Hi Everyone!
My 99 740i displayed the "Check Coolant Level". I stopped immediately and the engine was steaming. It has never overheated. I kept adding water/antifreeze every time before driving it.. (1 - 2 liters). When I got a chance to put it on a lift, I discovered where it was leaking/dripping from.. Right in the miiddle. behind the gear box. I was hinted it might be heater core leak?! Radioator was reaplced less than 10k miles ago. Anyone else concurs? I have to put it on a lift again and inspect fully (as I did not get a chance to do that). Anyone else experience the same problem? Here is a poor quality shot from my C-phone. (Those are front wheels)
Help! My 740i Is Dripping-740_heater_leak.jpg   Help! My 740i Is Dripping-740i_heater_leak2.jpg
abdoul is offline   Reply With Quote
Old 12-12-2004, 06:44 PM   #2 (permalink)
billB's Avatar
I think for a heater core you better off checking leaks from above if you can see those small hoses going into the firewall check them for leaks anyway.
Old 12-12-2004, 06:54 PM   #3 (permalink)
Moderator
Dirty_Tool's Avatar
If the coolant is coming from inside the transmission bell housing then you may have a "belly pan" leaking. This is the cover to a coolant channel which runs along the top of the block. Unfortunately to replace the belly pan the intake manifold must be removed.
Not sure if this is the type of leak you are describing but if not its something else to check.
DT
DT
Urgent Help - Cant get into boot on my 740i fuzioneer 1,6,7,8 - Series and Mini Cooper 2 09-12-2005 05:14 PM
1997 740i E38 Service Manul jmnz003 1,6,7,8 - Series and Mini Cooper 2 05-06-2005 09:50 PM
Looking For 1995 740i Carpet & Audio/video Options gezzuzz 1,6,7,8 - Series and Mini Cooper 0 03-10-2005 12:42 PM
2001 740i navigation on a 98 740i bmw. nap21 Audio and Electronics 4 11-09-2004 05:31 PM
clutch master cylinder help! imprttuner88 3-Series (E21, E30) 1 02-05-2004 10:04 PM
