HELP buying 1997 740IL - BMW Forum - BimmerWerkz.com
Old 02-11-2006, 07:44 AM   #1 (permalink)
revjim is on a distinguished road
I have the chance to purchase a cosmetically nice 740IL from my father in law for 5,000.00. It has 85000 miles on it. Gentle miles. The guy is just a passive calm person. However, I took it to a BMW guy locally and he said this is the list...R/F wheel bearing starting to make noise, L/F lift pad is missing, L/F strut is bad, Left Catalytic converter is rattling, Timing covers are leaking, but not bad, probably needs an intake manifold gasket/valve job.
You guys know best. I have seen DIY's on this stuff and all look easy accept for the timing covers.
IS THIS A GOOD DEAL or should I walk?
Thanks,
MY FIRST BMW!
revjim is offline   Reply With Quote
Old 04-02-2006, 09:27 AM   #2 (permalink)
Tom Taylor is an unknown quantity at this point
Buying 740i
Does the car run shift& Idle OK? R U mechanic and or do you know one you can trust?these can be great cars but you have wonder why they depreciate
so bad.I have one its a 94.your`s sounds like its been neglected,which can been as bad as beeing dogged.this is a heavy car and it costs alot to hotrod
it.example you don`t cut the rotors you replace them.there around 180.00to250.00 each it will only be worth what you paid for it so unless its free.its a bottomless pit:
Tom Taylor is offline   Reply With Quote
Old 04-02-2006, 11:01 AM   #3 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
I think I'd do that if I wanted a 7, and pretty happily.
Lindsay fan club member.
Please Help If You Have Carfax Time Left. ozbmw 1,6,7,8 - Series and Mini Cooper 4 08-07-2007 08:48 PM
Buying 1997 Bmw 318i - Need Your Help! newbmw 3-Series (E36) 7 09-06-2005 08:04 PM
1997 740il Won't Start mgblizzie 1,6,7,8 - Series and Mini Cooper 7 04-23-2005 04:11 AM
1997 740il can anybody help factory television carcrazyinc 1,6,7,8 - Series and Mini Cooper 0 08-18-2004 01:15 AM
Buying 740iL Sport. Tranny differences??? Bread Bimmer Talk/Motorsports Talk 2 06-27-2004 04:34 AM
