HELP ! 97 BMW 750 Water Pump Removal - BMW Forum - BimmerWerkz.com
Old 12-05-2009, 09:05 PM   #1 (permalink)
SoCal750iL is on a distinguished road
I have the water pump exposed but I need to remove the Crank Pulley & Harmonic Balancer (I think!) to remove the water pump. I tried using an impact on the crank bolt but it wouldn't budge. I even snapped off the head of my breaker bar! Any suggestions on procedure, short cuts, and/or special tools needed for job would be appreciated. Thanks
SoCal750iL is offline   Reply With Quote
Old 12-05-2009, 10:06 PM   #2 (permalink)
CanyonCreekMT's Avatar
Car: 2006 750Li
CanyonCreekMT is on a distinguished road
Not sure about BMW but you might want to check and make sure it is not a left handed thread. I have known a few folks that have broken stearing wheel bolts because they are left Handed threads.
CanyonCreekMT is offline   Reply With Quote
Old 12-05-2009, 10:18 PM   #3 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
Found these links to help you with your e38 & water pump!
There should be 8 smaller bolts inside the dampner......that you have to remove, not the large crank pulley bolt!
http://www.magnum1.com/BMW-740/740_P...-Pump-740.html
e38.org BMW 7-series information and links
jb
Old 12-05-2009, 10:37 PM   #4 (permalink)
There are no bolts on or in the balancer but thanks for tryin. The E38 Model w/ the M73 Motor Water Pump is such a pain and different from other models.
Old 12-05-2009, 10:56 PM   #5 (permalink)
Check out page 20 of 31
http://www.bimmerboard.com/members/d...eplacement.pdf
jb
• Remove the belts by undoing the tensioners
• Remove the water pump pulley
• Remove the crankshaft bolt and harmonic dampener
Warning: The crankshaft bolt is very difficult to remove. My experience required the
following efforts to remove the bolt:
• Locked the crank by locking teeth on the flywheel at the transmission
• Heating the bolt to red hot
• Soaking the bolt with a penetrant after heating.
• Using a 24” break bar with an additional 48” cheater bar
• 600+ ft/lbs torque wrench.
WOW
water pump oted 1,6,7,8 - Series and Mini Cooper 2 08-30-2008 10:26 AM
Water Pump TeeUp 3-Series (E36) 23 11-26-2007 07:03 AM
E38 98 or under water pump for non water cooled alternators brand new AlpineSixAndSeven OEM Parts 0 10-12-2007 03:58 PM
540 - Water Leak - Radiator? Exp Tank? Water Pump? windarra 5-Series (E12,E28, E34, E39, E60) 2 06-09-2006 10:13 PM
Water Pump '93 93 325i 3-Series (E36) 5 09-22-2004 01:23 PM
