Help! - BMW Forum - BimmerWerkz.com
Old 01-13-2005, 12:06 PM   #1 (permalink)
88750iL is an unknown quantity at this point
Hey all,
im a newbie.
Well i have a 1988 750iL and my car starts oveheating really bad, i found out a hose was broken in the front and it was leaking water. Could this be it?
My second Question: Where is the Battery located?
My last question is; My car makes a loud beeping niose every minute or so is this normal, it gets quite anoying, or could it be becasue it was over-heating?
Thanks,
Danny
88750iL is offline   Reply With Quote
Old 01-18-2005, 12:17 AM   #2 (permalink)
robob69 is an unknown quantity at this point
Send a message via Yahoo to robob69
The battery should be located under the rear seat on the passengers side.
Take care
Robert
Houston, Texas
<span style='font-family:Courier'>Robert</span>
Houston,Texas
robob69 is offline   Reply With Quote
Old 01-20-2005, 08:13 AM   #3 (permalink)
Correct the battery is under the left rear passenger side seat cushion and a bear to get the cushion back in.
Overheating, is it all of the time, at speed, in traffic, etc. If she overheats in traffic but is OK on the road, then I woul suspect the fan clutch.
If you email me I will send along some OBC tips as well as my way to remove/reinstall the rear seat cushion/s.
Old 01-25-2005, 10:08 PM   #4 (permalink)
[snapback]275486[/snapback]
can you please send me that info at redwoodlyricist@sbcglobal.net
thank you.
Old 01-25-2005, 10:11 PM   #5 (permalink)
It seems like i have even a greater problem now... my car doesnt open when i put the key in! that sets back all the othersuff i have to fix... Can anybody give me any suggestion on why this happened and how i can open it???
thanks!
Danny
Old 01-25-2005, 10:34 PM   #6 (permalink)
Pimpin A 6's Avatar
Pimpin A 6 is an unknown quantity at this point
check your relays....that problem with the ignition happened to me. and it was a complete pain inthe ass. relays arent cheap. also check ur alarm system if you have one. that may also be causing a problem. and when u switch relays make sure u put the right ones in the right place....that also happened to me
Pimpin A 6 is offline   Reply With Quote
Old 01-30-2005, 11:32 AM   #7 (permalink)
okay opened the car fixed everything but my AC is frozen, anyone know if i could fit anyother kind of ac of ov'e any other type of BMW?
thanks.
Help! Help! Help! dvmotorsports 3-Series (E36) 6 06-02-2005 12:51 AM
Need Help! Car Is Barely Drivable komodo 3-Series (E36) 79 03-26-2005 10:41 AM
Help! My a/c will not turn on! jroberts312 3-Series (E36) 7 05-28-2004 03:30 PM
clutch master cylinder help! imprttuner88 3-Series (E21, E30) 1 02-05-2004 10:04 PM
2001-2003 M3 Steering. Need Help!? BMWPro77 3-Series (E46, E90) 6 01-31-2004 07:22 PM
