Having some problems. e32 740il - BMW Forum - BimmerWerkz.com
Old 06-21-2008, 06:12 PM   #1 (permalink)
SVK
SVK's Avatar
SVK is on a distinguished road
Angry Having some problems. e32 740il
I have a 1994 e32 740il, I had this car for a long time and it runs fine, but two days ago a noticed a smell coming from under the hood. I can't identify the smell, it is not oil or gas??? The car is running fine, no power reduction or overheating, all of the sensors tell me that the weather is good??? Can some one help? Thanks.
Oh yea I live in Vegas so it is really hot (110F+).
SVK is offline   Reply With Quote
Old 06-21-2008, 06:25 PM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
Is it a kinda sweet smell? it is probably coolant... check coolant level fill to the line and check it in a couple days... mostlikly a small coolant leak....
1992 318i Coupe parts car
I am Captain Obvious
Old 06-22-2008, 10:59 AM   #3 (permalink)
SVK
SVK's Avatar
Lightbulb
I do have a very small coolant leak at the back of the motor, but I check my coolant every day and it is not leaking bad. I have to add some every half a year. Could this be coolant that is just being cooked on the block, because of the Vegas heat. I ran my car at night so the air is cooler for the same time and the smell was not there.
Old 06-22-2008, 06:53 PM   #4 (permalink)
Smell
I had a '88 750 and it had a coolant leak from the hoses under the expansion tank, and the block was hot enough to burn the coolant down and create a smell (this was in SE Virginia, not Vegas heat), keep an eye on the leak, if a hose blows you are dead in the water
Old 10-21-2008, 10:28 PM   #5 (permalink)
iana is on a distinguished road
Hi,
May not hurt to check water (radiator) filler cap, they were recalled for a fault mine was fine then progressively over pressurized the system a replacement sorted it. It started leaking at the weakest point then went balistic!
Ian
iana is offline   Reply With Quote
e32 740IL Bentley PDF xchanger 1,6,7,8 - Series and Mini Cooper 0 04-12-2008 08:07 PM
740il e32 window issues bjk1159 1,6,7,8 - Series and Mini Cooper 4 03-25-2008 03:58 PM
e32 heater blower problems bjk1159 1,6,7,8 - Series and Mini Cooper 3 01-20-2008 12:50 PM
E32 740iL M ? hah! Trevize Driving Tales 1 07-05-2007 07:31 AM
E32 Drive shaft Problems edbolz 1,6,7,8 - Series and Mini Cooper 1 04-21-2004 02:49 AM
