Glovebox cylinder lock removal ? - BMW Forum - BimmerWerkz.com
Old 06-13-2011, 08:43 AM   #1 (permalink)
Car: 740 iL
stilllearning6 is on a distinguished road
1998 740 iL : Glovebox plastic latch snapped in 4 places . Epoxy could not salvage it .
Have new latch that requires the old cylinder .
How do you remove old cylinder from the plastic latch ?
I found at least 2 postings ( by Franco90 , author) with pics , but could not get cylinder out.
I see 2 side wings/ release tabs that may require outward flexing.
I can place key into cylinder and turn the cylinder to line up the cylinder walls with the channels .
Read that key must be in cylinder or else the cylinder parts fall out as you slide cylinder outward .
Is there some step involving the steel silvery pin / rod that protrudes in the back of the latch ?
I am guessing that spreading of the shoulder wings is required plus at least one other step .
stilllearning6 is offline   Reply With Quote
Old 06-13-2011, 12:07 PM   #2 (permalink)
Car: 740 iL
To release the lock cylinder from the latch , I had to totally destroy the 2 side tabs/ side clips/ side hooks which collar the cylinder .
They act as a tighter collar than the rest of the sleeve and encircle a recessed narrower neck area in the cylinder. Until these 2 side tabs/ clips/ hooks are bent way back from the narrow recessed neck , I was not able to slide the cylinder out from the main latch body. After this step, my latch body was decimated , chewed , snapped --> worthless.
Old 10-27-2011, 08:57 AM   #3 (permalink)
justabonehead is on a distinguished road
getting cylinder out
Put key in and turn 1/2 way between OPEN and LOCKED. Pull gently and cylinder should slide right out.
justabonehead is offline   Reply With Quote
Door lock cylinder-removal 86325E 3-Series (E21, E30) 2 01-14-2012 11:53 AM
Ignition Lock Cylinder Removal snpower 3-Series (E21, E30) 2 02-23-2008 08:32 AM
Bmw E30 3 E34 5 Series Z3 7 Glovebox Handle Lock Latch Beeches OEM Parts 0 07-16-2006 12:23 PM
Glovebox/dash Removal bmwultdrivinmach 3-Series (E36) 0 06-08-2005 09:17 AM
E39 Touring Glovebox Removal? Wardy 5-Series (E12,E28, E34, E39, E60) 1 11-27-2004 09:28 PM
